Author Topic: Just swapped 350 wont start HELP!  (Read 3545 times)
Offline BigYellow17
« on: May 27, 2014, 02:57:46 pm »
Just swapped a 350 into the truck. Itsa a 4 speed manual it wont crank all the way over but does crank a bit... i attached wrench to crank and can crank engine over with the vehicle in gear.... Any ideas? the starter is engaging is my clutch possibly not dis engaging? Help please!
Offline rich weyand
Re: Just swapped 350 wont start HELP!
« Reply #1 on: May 27, 2014, 03:45:35 pm »
Did you replace the starter cables when you put in the new engine?  They go bad after 10+ years, but may work fine until disturbed.  You can check them by putting a voltmeter from the starter hot terminal (where the big red cable connects) to the frame, and reading the voltage while someone cranks the engine.
Offline BigYellow17
« Reply #2 on: May 27, 2014, 05:04:26 pm »
Ok i will check the cables. What about me being able to crank the crank over with a wrench while in gear? And i believe my battery is dead now i dont know what would be draining it
« Reply #3 on: May 27, 2014, 11:07:09 pm »
is it spinning fast enough?
what you mean crank over with a wrench?
are you jumping the starter in gear?
are you getting power (12v) to the distributor?
are you getting spark?
are you getting fuel?
Offline BigYellow17
« Reply #4 on: June 01, 2014, 10:30:43 am »
I did get it started .... Easy as my dang battery went dead ha. Rookie move!
