Author Topic: New parts ordered!  (Read 7458 times)
Offline 76k104x4
New parts ordered!
« on: July 11, 2014, 05:44:49 pm »
After getting my new headers installed the factory plug wires touch the header tubes on my 454. Also I figured it's about time to replace the distributor too so I ordered a distributor, HEI corrected cap, jegs 8.5 cut to fit wires with multi angle boots, plug wire boot heat shields, Moroso wire looms, and a Moroso recurve kit. I can't wait for parts to start showing up. Any suggestions about install?
Re: New parts ordered!
« Reply #1 on: July 11, 2014, 07:54:44 pm »
     If you are talking distributor, find TDC, make sure your rotor is pointed at #1 cylinder and remove, re-install as you removed.
Offline 76k104x4
« Reply #2 on: July 11, 2014, 09:33:02 pm »
Thanks Bake. Does anyone have any experience with putting in the recurve kit or suggestions on it?
Offline swilliams
« Reply #3 on: July 13, 2014, 12:17:02 am »
This is one thing I have read Truck not running right after a recurve kit.
« Last Edit: July 13, 2014, 12:40:12 am by bd »
Offline 76k104x4
« Reply #4 on: July 13, 2014, 12:35:34 am »
The link isn't working.
« Reply #5 on: July 13, 2014, 12:49:10 am »
@ 76k104x4 - try the link now.
@ swilliams - take a new look at your post to see how the "Hyperlink" code is used.   ;)
Offline swilliams
« Reply #6 on: July 13, 2014, 10:31:28 am »
Sorry about the messed up link.
Thanks for the correction bd
Offline 76k104x4
« Reply #7 on: July 13, 2014, 10:25:06 pm »
No problem thanks guys. Y'all make this a great site.
