Author Topic: Is it normal for fuel to non-stop gush out the fuel pump when NOT running??  (Read 5245 times)
Offline 74k20
Quick fuel pump sanity question.
New standard mechanical fuel pump on my new sb400.  When I hooked up the truck line INTO my fuel pump (carb not on yet), gas started flowing OUT the outlet (gas all over the place)  NO biggy, I quickly capped off the outlet (after gas all over the place).  But I thought fuel didn’t flow unless it was pumping?  No biggy and I ignored it (after cleaning up gas all over the place).  Then right before firing up the new motor, I decided to do a double check of the brand new QJ carb to insure there was actually a filter in the carb.  YEP…fuel gushes out NON-STOP (gas all over the place).  Carb is higher than pump, but gravity seems to be pushing fuel out with some force/pressure.  I seem to remember changing filters, lines, ect without this much fuel spilling all over thru the fuel pump.
Heat may be building pressure, to you have your vent plugged at the charcoal canister?
Offline 74k20
74 had no canister that I know of, as I believe all is original.  It was a bit warm out tho, so maybe pressure was built up in the tanks???  It flows QUITE well out the lines.
If 74's don't have vent lines than the gas cap has to be vented.  When you remove the gas cap is there pressure behind it?
^^^^^  X 2
The tank(s) have to be vented to breathe and properly deliver fuel - either through lines plumbed to a vapor canister or via the gas cap(s).
Take the gas cap off when you open the fuel system. If your tank isn't vented some guys will drill a small vent hole  on the inside of the cap to cheat
Offline 74k20
Good points guys...both new caps, but I don't know if vented or not.  I'll check as that makes sense - thanks
Offline enaberif
My 74 has a charcoal canister. Its down under the left headlight. Check there.
