Author Topic: Testing fuel sending unit  (Read 3777 times)
Offline Cory
« on: August 01, 2014, 02:37:36 pm »
Does anybody know which terminals on the headlamp switch do you connect the pink wire and ground wire going to the sending unit in order to test it? I read an old post from HAULIN IT that said you could use an old headlamp switch as a variable resistor and use it in place of the fuel sending unit to see if the gauge moves or not, but there are several different numbered terminals on the dimmer switch. I'm not sure which terminals to use. Any help would be appreciated!!
86 C10 350/700r4 single tank under the driver
Re: Testing fuel sending unit
« Reply #1 on: August 01, 2014, 04:03:21 pm »
Use the two terminals circled in red, below.
Offline Cory
« Reply #2 on: August 01, 2014, 04:13:01 pm »
Thank you bd!!
« Reply #3 on: August 01, 2014, 11:00:33 pm »
whats your gauge reading?
