Author Topic: New LED tailights available - in catalog soon  (Read 77026 times)
« on: August 18, 2014, 12:34:18 am »
Just got stock of these and will be in the catalog soon.  They come complete as pictured and replace the existing lenses.  Have LED backup, Rapid fire brakes and sequential lights (can be turned off) 20 4 pin LEDs for stop and turn, 9 for sidemarker.  Comes with everything you need.
2 versions are offered.  Chrome trim $199.99 or no chrome trim $189.99
I will have a write up on these soon.
Re: New LED tailights available - in catalog soon
« Reply #1 on: August 18, 2014, 06:29:02 pm »
     Any plans for the round one's for step sides ?
Offline KWKENUF
« Reply #2 on: August 18, 2014, 07:31:52 pm »
Interesting stuff.  Don't know how I feel about the rapid fire brake function though.
At one time I had started to attempt to build some custom LED lights for my Monte SS.  I was going to test on the SS and then make some for my truck.  Obviously never happened,  but this makes me want to revisit the issue...
« Reply #3 on: August 19, 2014, 11:17:54 am »
Rapid fire and the sequential can be turned off on them.
Bake, many places make LED trailer light that can be adapted to stepsides. Not sure that they will be on the list.  I have however asked them to look into making them for the 73-80 fronts.
« Reply #5 on: August 20, 2014, 09:57:37 am »
How does the brightness of these new lamps compare to the brightness of the other LED kit you sell?
« Reply #6 on: August 20, 2014, 08:20:31 pm »
There will be a comparison soon...
« Reply #7 on: August 24, 2014, 01:13:32 pm »
BTW these carry a 6 month warranty per the manufacturer.
Offline roundhouse
« Reply #8 on: August 28, 2014, 04:20:52 pm »
got a question
Im looking for a device that will flash my LED brake lights once or twice, then stay on
anyone know where I can get this?
Ive seen em on the brake lights on some ambulances and firetrucks and garbage trucks etc.
« Reply #9 on: August 30, 2014, 10:07:57 am »
that is built into these.  it is on the board for the LED's.  Flashers for the ambulances are another thing...
Offline roundhouse
« Reply #10 on: August 30, 2014, 05:41:29 pm »
Where do you get the built in part?
Is that avail separately !
So I could add it to a existing light !
I want to convert the cargo lamp on the back of the cab to a third brake light and when you apply the brakes I want it to flash once or twice and then stay on.
« Reply #11 on: September 03, 2014, 07:59:30 pm »
No idea the company that designed them would have to answer that.  I am sure they won't give it up willingly though.
Offline Displaced_Txn
« Reply #12 on: September 13, 2014, 01:48:02 am »
Now I need these for the k5. >:(
Offline ehjorten
« Reply #13 on: December 03, 2014, 01:37:51 pm »
Capt;
How do these plug into the original socket?  Is there a pigtail on that bulb connector that has some slack for you to install it, or do you have to 'free' your truck side socket from the original 'reflector' housing?
Also...how is moisture managed in these lamps?  Is the LED and control board fully-potted?  Any water seals to resist water intrusion?
Thanks,
Erik
-Erik-
« Reply #14 on: December 05, 2014, 11:27:17 am »
The original bulbs twist into the back panel.  The side marker is no longer used.  A loom runs across to the opposite side.
The rear panel is sealed against the lense just like the factory.
