Author Topic: What's broke? 350 sounds like an IDI diesel & slightly glittery oil. CRAP!!!  (Read 13801 times)
Offline thefarmboy21
Well my Fresh'ish 350 that I just dropped in my 86 has got my blood pressure up. I've been noticing it sounds kind of like an old IDI non turbo diesel.....not loud just kind of rattly. It doesn't sound like a knock, but not like valve chatter either really. And it's really quiet but I know it's there. Also when I changed my oil, the oil out of the pan looked fine from what I could tell. I stuck a rag under it and rubbed my fingers in it as it flowed out and looked normal. Then I dumped the filter and it looked fairly pearly coming out. Not like big glitter or overly silver'ish but definitely had some shiny stuff mixed in coming out. SOOO......now I'm wondering what happened. Main bearing, cam bearing, wiped cam/lifter, OR is it just breaking in more. Idk. I build the bottom end in 2009 I think? Ran it in my derby car for a while with no problems and tons of power. Then heads had to be changed so I threw a set of centerbolts on it and into the K20 it went. I don't know what kind of oil pressure it has because my gauge quit and just stays at 20psi running or not.....but I've got a new one to put on this weekend.
THOUGHTS????
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
Pearly oil most likely is from wiping cam lobes/lifters.  Did spring changes increase pressure with the new heads?  Did you use ZDDP enriched oil?  I agree, you need to check and monitor the oil pressure - maybe even drop the pan.
Is the rattle emanating from the valve covers - as in noisy roller rockers?  If you're running forged pistons, the noise maybe slap - although that should diminish as the engine warms.  Wrist pin is another possibility, as is preignition.
Try to determine whether the noise is from the top or bottom.
« Last Edit: September 26, 2014, 11:25:31 pm by bd »
Just has stock valve springs and stock stamped rockers with only .462/.447 lift. Basically an RV cam in a stock motor. Bottom end is a 70-72ish 350 from a truck. I rebuilt it a few years ago. I run RotellaT 15w40 because it has more zinc. I listened with my stethoscope and can't really pinpoint it. Sounds the same if I take the breather/pcv valve out and listen. SO......I'm also kind of leaning towards a cam starting to wipe. This seriously sucks.
Offline Engineer
Give each of your rocker arm nuts a 1/4 turn and see if the noise goes away. Had to do that on my '94 K2500. My cam was fine, the lifters just needed to be reset.
My first oil change on my '77 truck's 454 had lots of glitter out of the oil filter. Everything in that engine was new save for the block, and head castings. I chalked the glitter up to the break in wear from the piston rings.
And you really need to get an accurate oil pressure gauge.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
I'm going to install the new gauge sometime in the next few days and adjust the valves again. The reason the glitter worries me is because it should be broke in. That motor has been through about 15 heats of derby since 2009, plus all the test&tune time around the garage in the derby cars. I had to change the heads because we floated the valves a couple times and the bronze valve guides shoved through on the race heads that it previously had. SO, that's another reason I'm worried about the cam.
*IF the cam is wiped, but motor has good oil pressure, would a quick cam swap and a couple oil changes be enough to flush the motor? OR are the bearings likely shot now?
Accumulated hours on the engine is why I suggested cam/lifters.  Even so, you realize this is cracker barrel conversation.  The only way to know is to look.  That said, a good oil filter should protect rod/main/cam bearings.
Adjust the valves and check for obvious loss of lift at the rockers.  Cam failures develop fairly quickly.  If looseness recurs in the valve train, you'll know.
Offline Dan75k20
They have been removing zddp from rotella!
Offline Engineer
If your cam wiped a lobe the oil filter should have caught the metal.
Well I smacked my gauge a few good times and  it sprang up to 40+ psi at idle. I'm still going to change it out and check but I can watch the oil shoot up the plastic line when I start it, so I'm hoping I'm good. I'll check the lift with my dial indicator as soon as I get a free couple hours. As said, the oil looked normal flowing out of the pan, I didn't find any shimmer until I Dumped the filter, so I'm pretty hopeful the bearings are ok and that worst case scenario is swap the cam with the motor in the truck.
How do you all adjust your valves? Tey way I've always done it was tighten them to zero lash and when I can't rattle the pushrod anymore, but can still spin it freely, then tighten it just barely until there's resistance when I spin the pushrod. I never really thought the extra 1/4-1/2 turn sounded like a good idea. To me it seems like the valves wouldn't close? BUT now I'm wondering if I did something wrong.
My buddy just gets them close and then starts it up and backs them off until they tick, then tightens them back up until the ticking stops.
Offline jaredts
Exhaust opening, intake closing--EOIC method.  Just google that, as it is probably the most common method.  Assuming you have hydraulic lifters, you can also start the engine with a valve cover off, back one off until it ticks, turn it until it just stops ticking, and then give it a 1/4 to 1/2 turn.  The extra 1/4 to 1/2 turn is important, otherwise you are right on the edge of being loose and having ticking valves.
Re: What's broke? 350 sounds like an IDI diesel & slightly glittery oil. CRAP!!!
« Reply #10 on: September 28, 2014, 12:39:31 pm »
Frankly, the answer to your question on the preferred method of hydraulic valve lifter adjustment depends on who answers.  GM recommends a method of valve service adjustment that works well for stock to mildly modified engines.  For example, look in the 1987 Service Manual, pages 525 & 526 (6A4-6/6A4-7).  Some techs decry GM's approach as problematic.  On the other hand, EOIC is broadly used for all builds with good success, as is the wet method (engine running) described by jaredts.  The main drawback of the 'wet method' is the consequent and unavoidable mess.
Regarding lifter preload, the GM spec of one full turn after zero lash approximately centers the plunger in the lifter body - a good choice for a stock to mild build DD that won't see regular high RPM use (above ~4,700 RPM).  Adjusting the lifters to less than 3/4 turn, arguably, can benefit high RPM use by decreasing the tendency for the lifters to "pump up" and temporarily hold the valves slightly open once they begin to float.  Realistically, if you are floating the valves there is a spring problem or you're abusing the engine by pushing it beyond its build limit.
Comp Cams simply recommends zero lash (no preload) with some of their performance hydraulic lifters.  I disagree with this approach for street builds as it virtually defeats the purpose of having hydraulic lifters.
For your type of application I have used the GM method, EOIC, and the wet method with similar good success.  For what it's worth, now I use the EOIC method fairly consistently.
« Reply #11 on: September 29, 2014, 08:20:51 pm »
I got my new oil pressure gauge installed and I DO have good oil pressure. It's idling at about 600-650rpm and has 50psi idling from a cold start and remained the 10 minutes or so I let it run. Went past 60psi when I revved it up. After I installed the new gauge and before the startup, I removed the valve covers so that I could watch the rocker arms. All rockers APPEAR to be in full lift, but I know it would be hard to tell if it's in the early stages. HOWEVER I did not have any ticking rockers and I would've thought that a wiped love or worn lifter would've caused a lifter tick from lost lift? Anyway I used the the wet method and adjusted them all after the oil warmed up a bit. They all seemed to be pretty dead on.
*The only thing I wasn't sure about, is that it took a good minute or two for oil to make it up to the rockers....some oddly longer than others but eventually all had a nice flow. Maybe because it was idling at <650rpm?
The strange noise is still there and I have no idea what it is. -_-
« Reply #12 on: September 30, 2014, 11:28:54 am »
I also want to note that while searching today I kept finding posts in various forums about similar issues.....all saying that it took longer than normal for the rocker arms to get oil to them and once they got oil it just kind of seeped out rather than ran out causing the normal mess. Almost all of these came back claiming it was the aftermarket Hyd. flat tappet lifters (mostly from comp cams and a couple fr lunati) they claim they swapped lifters and all was well. Anyone had such an experience????
While adjusting my valves via the "wet"/running method, as soon as I snugged them down from ticking/clacking to quiet, if I went further the engine bogged. Is that the preferred stopping point or should they have preload? One place I read said adjust from clacking to quiet, then TURN IT OFF and proceed to crank all 16 and additional 1/2 turn?
« Reply #13 on: September 30, 2014, 12:40:24 pm »
...While adjusting my valves via the "wet"/running method, as soon as I snugged them down from ticking/clacking to quiet, if I went further the engine bogged. Is that the preferred stopping point or should they have preload?...
This is normal.  Once you remove the initial lash, adjust the additional turn s·l·o·w·l·y over 10+ seconds.  The lifters will bleed off, the valves will close and the engine will idle normally.
« Reply #14 on: September 30, 2014, 12:55:52 pm »
So an additional 1/2 turn each or what?
Better to do SLOWLY while running, or just shut it down an do it not running? I mean is one preferred over another?
