Author Topic: 85 K5 Blazer LS swap  (Read 40876 times)
Offline Kevin_J_Pugh
Re: 85 K5 Blazer LS swap
« Reply #15 on: January 14, 2015, 07:17:52 pm »
What did you do about the speedometer and other gauges
Offline LTZ C20
« Reply #16 on: January 14, 2015, 09:07:58 pm »
Very nice turn out on this project.  You did a good job and it looks really cool. I did a carb to TBI swap on my truck a while back and I love how reliable it has been to just let the computer handle it all and I enjoy it.  I hope your enjoying your hard work.
LTZ Cheyenne C20
Offline roundhouse
« Reply #17 on: January 15, 2015, 09:38:45 am »
Guy near me sells 5.3 LS motors with all accessories wiring harness and reprogrammed computer , ready to run for $1100
Wish I had known about that before i spent $500 adding TBI to an old carbed 350
Offline FlatBlack77
« Reply #18 on: January 15, 2015, 10:28:02 pm »
wow that sounds like a killer deal
Offline roundhouse
« Reply #19 on: January 16, 2015, 09:16:21 am »
Yep
He has installed em in a pair of 72 C-10s for his twin 16 yr old girls
Offline PTNOUT
« Reply #20 on: February 25, 2015, 10:00:48 am »
Roundhouse where is that at?
Offline roundhouse
« Reply #21 on: February 26, 2015, 07:29:25 am »
in Atlanta
678-314-07 nine. Six
Guys name is John
Offline jason
« Reply #22 on: April 03, 2015, 02:31:32 pm »
Did you run your own vss from the transfer case? How did you get the wiring to work well without all the inputs from the pcm?
Offline vr4oaks
« Reply #23 on: April 04, 2015, 12:16:11 am »
With wiring instructions and/or tuning the stock ecm go to http://lt1swap.com/
-vr4oaks
1979 Chevy c10, Super HX30, POD Injectors, Timing and Fuel turned up, FASS 15 PSI Fuel Pump, BHAF, Autometer Pro-Comp 2 Boost and EGT gauges, 4" MBRP Dodge Cummins Exhaust, 12" 273 welded rear-end, max boost 40 pounds, max EGTs 1500, Hydroboost
