Author Topic: Vent Window sticking..  (Read 6746 times)
Offline IdahoMan
« on: October 10, 2014, 01:59:54 pm »
My passenger side vent window is getting stuck. The top tip of the window is catching on the frame as seen below.
Any idea what to adjust/check to fix this?
-IM
Re: Vent Window sticking..
« Reply #1 on: October 10, 2014, 06:30:49 pm »
Is it loose (no tension)?  There is a spring on the bottom side sometimes they can get like this when they are broken or the spring falls off...
http://forum.73-87chevytrucks.com/smforum/index.php?topic=27075.0
Offline IdahoMan
« Reply #2 on: October 10, 2014, 07:12:02 pm »
It's nice and stiff. Takes quite a bit of pressure to pop the window open, and a bit of pressure to pop it back closed.
« Reply #3 on: October 10, 2014, 09:09:58 pm »
What does the hinge area look like?
Offline IdahoMan
« Reply #4 on: October 11, 2014, 01:24:36 pm »
« Last Edit: October 11, 2014, 02:04:09 pm by IdahoMan »
« Reply #5 on: October 14, 2014, 09:11:40 pm »
That isn't quite the same vent/truck.  Can you post a pic of the whole window and one of the top and bottom portion.
Offline IdahoMan
« Reply #6 on: October 16, 2014, 02:49:34 pm »
pics
« Reply #7 on: November 24, 2014, 02:19:36 pm »
What does it look like inside the door?
Offline dvdswan
« Reply #8 on: November 24, 2014, 10:53:40 pm »
it almost looks like they are windows for a "G" van.  but I don't think they would fit in the truck frame.
« Reply #9 on: November 25, 2014, 09:44:04 am »
The way it is swinging makes me think there is something wrong with the lower portion of the pivot.
