Author Topic: hydro boost issue  (Read 6455 times)
Offline duallydmax06
hydro boost issue
« on: November 09, 2014, 03:08:13 pm »
Hello everyone, im working on a 84 gmc 1 ton crewcab dually 2wd with a 454 it has the hydro boost system on it and my problem is the other day the brake light came on and i lost power brakes the truck still stops you just have to press real hard now. The weird thing is the power steering still works great, acouple days ago i put some lucas power steering additive in for the leaky gear box that stuff slowed the leak down on my 85 so figured i try it on this one, anyone have a idea whats goin on here since the power steering still works????
2010 ccsb 4×4 duramax
1985 sclb k20
1979 sclb k20
1971 sclb c20
1928 model a coupe hot rod
Re: hydro boost issue
« Reply #1 on: November 09, 2014, 05:39:56 pm »
Those "fixes" swell rubber seals, OK for just power steering, probably not OK for the hydraboost unit...
« Reply #2 on: November 09, 2014, 10:44:33 pm »
It acted up the same day the lucas stuff went in you think it did damage to the hydroboost that quick?
1985 sclb k20
1979 sclb k20
1971 sclb c20
« Reply #3 on: November 10, 2014, 01:08:11 pm »
Anyone else have any ideas???
1985 sclb k20
1979 sclb k20
1971 sclb c20
Offline bd
« Reply #4 on: November 10, 2014, 01:31:59 pm »
Make sure the master cylinder is full of fluid, check the rear drum brake adjustment and inspect the calipers, rear wheel cylinders and all brake lines for leaks.
