Performance
edelbrock high idle issue 86 k20
Topic: edelbrock high idle issue 86 k20 (Read 6468 times)
jc1224
November 27, 2014, 08:13:15 pm »
hey i have been having an issue that has been driving me nuts lately. i have an 86 k20 with a 1406 edelbrock i bought new 6 months ago or so on a stock intake with the adapter plate. th400 trans so no kickdown cable. when i start the truck the fast idle always seemed a little high so ibacked the bottom screw owm the arm back and didnt appear to change it but when i put it in gear and tap the throttle its stuck at about 12-1500 rs and when i come to a stop i have to put it in neutral and rev the piss out of it. to get the idle normal. take off and repeat. i also dont really have kickdown here lately. but in the last week i have replaced the throttle cable, spring and checked dor vac leaks. the choke works properly. i drive this truck 80 miles a day so its getting annoying any where i should look?
rich weyand
Re: edelbrock high idle issue 86 k20
November 27, 2014, 09:51:33 pm »
Sounds like the choke may not be adjusted correctly.
Are you sure you have the correct screw for the high idle adjustment?
jc1224
November 28, 2014, 05:09:07 am »
well i physically see the choke open when it warms, but ill try leaning it back some, and the screw should work, its the one that come on the carb
rich weyand
November 28, 2014, 09:49:54 am »
I understand that the carb has a high-idle screw. I'm wondering if you are adjusting the right one.
jc1224
November 28, 2014, 09:58:37 pm »
gotcha, yeah im adjusting the bottom one on the the throttle arm when you hold it at wot to get to it
Dr_Snooz
"I like to take hammers, and just break stuff"
November 28, 2014, 10:29:18 pm »
Check that nothing is causing your throttle linkage to hang up. I had a problem with that on my 1411.
reed85
June 04, 2015, 08:59:33 pm »
I have a 1406 and i had same problem look up adanved tuning the edlebrock on youtube ill try to get the link for you
Reed85C30
reed85
June 04, 2015, 09:02:59 pm »
http://youtu.be/hoXK9tm0bWk
Here u go this helped me
Reed85C30
Performance
