Author Topic: Ignition actuator - any better way?  (Read 38024 times)
Offline roundhouse
« Reply #45 on: December 08, 2014, 06:46:53 am »
I wouldnt fool with using the manual Collum
An auto Collum should be easy to find at any and every pick and pull
Manual columns are rare
Get a tilt Column while you swapping it
Look on CL. Most towns have a guy that rebuilds GM Collumns for $100 or so
We had an old junker with the same problem as you
We just bent the actuator rod sideways right at the dash
So you used the key to unlock the wheel and then pulled on the rod to start it
And pushed on the rod to stop it
« Last Edit: December 08, 2014, 06:49:03 am by roundhouse »
Offline Junkie
Re: Ignition actuator - any better way?
« Reply #46 on: December 08, 2014, 07:35:31 am »
Are you sure that's the direction it takes for yours? On mine I push on it to start and pull to turn it off. All the way out is acc, then lock/off, then run, then start is pushing it all the way in.
Is the tilt column a bolt in?
1973 C20, 350/350
Offline roundhouse
« Reply #47 on: December 09, 2014, 06:19:26 am »
Tilt column is a bolt in
We installed a tilt from a 82 in a 77
We needed all of the column down to and including the rag joint
Somewhere along the line GM reversed the direction of the rod
They are interchangeable and in fact use the exact same switch at the bottom    But the switch is just bolted on backwards
Same wire harness plug etc
Just take the two screws out flip the switch around and bolt it back on and plug the wires back in
Offline Junkie
« Reply #48 on: December 18, 2014, 09:32:21 am »
I ended up putting in a junkyard column. It came out of a '74 but it used a pull rod rather than a push rod so I suspect it may have been a swap. Additionally, it didn't use any torx bits that I saw - they were phillips instead.
Everything works well now, although I need to get the wheel centered so the turn signals cancel right.
1973 C20, 350/350
