Technical Forum (Read Only)
Computers, Fuel and Emissions
(Moderators:
bd
Obd1 code retrieval and decoding/troubleshooting
Topic: Obd1 code retrieval and decoding/troubleshooting (Read 110876 times)
Moderator
December 22, 2014, 08:33:32 am »
1. Jump terminals A and B (see diagram below) with the ignition "ON" and engine off. This will start the diagnostic mode. The computer will display a Code 12, three times, by flashing the check engine light. A Code 12 consists of one flash, a short pause, then two flashes three times.
2. Codes will be displayed by flashing the check engine light. All codes are displayed 3 times each then a code 12 will repeat and the trouble codes will start again.
code - code definition
12- diagnostic mode
13- 02 sensor or circuit
14- coolant sensor or circuit/ high temp indicated
15- coolant sensor or circuit/ low temp indicated
16- system voltage out of range
19- crankshaft position sensor or circuit
21- throttle position sensor or circuit- voltage high
22- throttle position sensor or circuit- voltage low
23- mixture control (m/c) solenoid or circuit (carbureted models)
23- manifold air temperature (mat) sensor or circuit (1990 and earlier models)
23- intake air temperature (iat) sensor circuit (fuel-injected models)
24- vehicle speed sensor (vss) or circuit
25- manifold air temperature (mat) sensor or circuit - high temperature indicated (1990 and earlier models)
25- intake air temperature (iat) sensor or circuit - high temperature indicated (1991 and later models)
26- quad driver module circuit
27- quad driver module circuit
28- quad driver module circuit
29- quad driver module circuit
31- park/neutral position (pnp) switch circuit
32- baro sensor or circuit (carbureted models)
32- egr circuit (fuel-injected models)
33- manifold absolute pressure (map sensor signal voltage high
33- mass air flow (maf) sensor or circuit - excessive airflow indicated
34- manifold absolute pressure (map) sensor signal voltage low
34- mass air flow (maf) sensor signal - low airflow indicated
35- idle speed control (isc) switch or circuit (shorted) (carbureted models)
35- idle air control (iac) valve/ circuit 38- brake switch circuit
39- torque converter clutch (tcc) circuit
41- no distributor signals to ecm, or faulty ignition module ( carbed models)
41- cylinders select error- mem-cal or ecm problem ( fuel-injected models
41- cam sensor circuit (3.8 engine)
42- bypass or electronic spark timing (est) circuit
43- low voltage at ecm terminal l (carbureted models)
43- knock sensor circuit
43-electronic spark control (ECS) circuit
44- oxygen sensor or circuit - lean exhaust detected
45- oxygen sensor or circuit - rich exhaust detected
46- power steering pressure switch circuit
48- misfire diagnosis
51- prom, mem-cal or ecm problem
52- calpak or ecm problem
53- egr fault (carburetor models only)
53- system over-voltage (ecm over 17.7 volts)
53- vehicle anti-theft system (vats) circuit
54- mixture control (m/c) solenoid or circuit (carburetor models)
54- fuel pump circuit (1986 and later models)
55- oxygen sensor circuit or ecm
55- fuel lean monitor (2.2l engine)
61- oxygen sensor signal faulty (possible contaminated sensor)
62- transaxle gear switch signal circuits
63- manifold absolute pressure (map) sensor voltage high (low vacuum detected)
64- manifold absolute pressure (map) sensor voltage low (high vacuum detected)
66- pressure sensor or circuit air conditioning
Last Edit: January 25, 2020, 08:05:34 am by Irish_Alley
Moderator
Code 13
January 09, 2020, 09:30:29 pm »
Moderator
Code 14
January 09, 2020, 09:31:45 pm »
Moderator
Code 15
January 09, 2020, 09:32:29 pm »
Moderator
Code 21
January 09, 2020, 09:33:38 pm »
Moderator
Code 22
January 09, 2020, 09:35:03 pm »
Moderator
Code 23
January 09, 2020, 09:35:37 pm »
Moderator
Code 24
January 09, 2020, 09:36:30 pm »
Moderator
Code 25
January 09, 2020, 09:37:11 pm »
Moderator
Code 32
January 09, 2020, 09:38:17 pm »
Moderator
Code 33
January 09, 2020, 09:38:53 pm »
Moderator
Code 34
January 09, 2020, 09:39:19 pm »
Moderator
Code 42
January 09, 2020, 09:39:59 pm »
Moderator
Code 43
January 09, 2020, 09:40:35 pm »
Moderator
Code 44
January 09, 2020, 09:41:20 pm »
(Moderators:
bd
