Performance
timing chain
Topic: timing chain (Read 11359 times)
dieselman123
professional
timing chain
January 09, 2015, 10:29:47 am »
hey guys i need some help. i bought a comp cam kit 12-235-2. my question is would it be ok if i use a stock replacement timing set from parts store or the one comp cam recommends. im building a 355 sbc with vortec heads. its going in 83 chevy c10 silverado trim. i want to go with the double roller timing set but not for sure if my stock timing cover will work with a double roller timing set. please help and thanks in advance
Gotta clean my back windshield cause I'm too busy kicking up dust
LTZ C20
Re: timing chain
January 09, 2015, 11:08:38 am »
I would recommend using the double roller set comp recommends.
LTZ Cheyenne C20
timthescarrd
Re: timing chain
January 09, 2015, 11:21:29 am »
Most of the popular parts stores (O'rielly, autozone, etc.) Sell double roller timing kits for SBC in the store
dieselman123
professional
Re: timing chain
January 09, 2015, 11:28:40 am »
will the stock timing cover have any trouble fitting over the doulbe roller. i have been reading that the stock timing cover will not fit
78BIG-TEN
Re: timing chain
January 09, 2015, 11:38:24 am »
it should fit
dieselman123
professional
Re: timing chain
January 09, 2015, 11:48:04 am »
i will try the one comp cams recommend hope the timing cover fit.
78BIG-TEN
Re: timing chain
January 09, 2015, 12:01:14 pm »
I've used them in many small block builds with no problems
LTZ C20
Re: timing chain
January 09, 2015, 12:08:07 pm »
The double roller set is more robust than the stock timing set. As well, if you use the set from comp, if you ever have a problem with the cam, it will be easier to warranty the cam if you use their parts along with it, if it can be warrantied. I used the comp cam and lifter kit 12-238-2 with a double roller set and comps solid one-piece chromoly push rods. I also used a stock replacement timing cover with the timing set. No problems.
LTZ Cheyenne C20
fitz
Re: timing chain
January 09, 2015, 02:27:12 pm »
I've installed a few Cloyes double roller timing chains into SB Chevy's. They fit under the stock timing chain cover.
Looking back its funny how as a kid installing a "double roller" timing chain into a worn out motor gave you instant bragging rights.
LTZ C20
Re: timing chain
January 09, 2015, 02:40:03 pm »
Haha yes it did. I just remembered that the double roller I put in my current 350 is a Mellings.
LTZ Cheyenne C20
enaberif
Re: timing chain
January 09, 2015, 05:56:36 pm »
Cloyes double roller.. CHeaper and good stuff. Don't get sucked into the large brand name stuff for cheaper stuff.
dieselman123
professional
Re: timing chain
January 13, 2015, 10:35:38 am »
ok guys i bought the double roller timing chain. at first it kind of hard putting it on because it seemed like the chain was too short but after fumbling around i got it on with no problem. got everthing in time like it should be. now i see just how stretched my old chain was. mane its a wonder the motor didn't jump timing. i can barely squeeze themiddle of the chain together. now thats tight. the factory timing cover went on no problem also. thanks guys for all you help!!! God I LOVE THIS FORUM CHEVY TRUCKS RULE!!!
78BIG-TEN
Re: timing chain
Reply #12 on:
January 14, 2015, 08:55:41 am »
Glad it worked out for you dieselman
LTZ C20
Re: timing chain
Reply #13 on:
January 14, 2015, 08:59:25 am »
Good too hear. Yes the double roller or a new timing chain makes a world of difference.
LTZ Cheyenne C20
Performance
timing chain
