Author Topic: Question on 85 k10 door switches  (Read 4868 times)
Offline true74yamaha
« on: January 18, 2015, 06:09:11 pm »
So I need new door switches LH & RH. I was looking at replacements. I only see replacements with two terminals like what the LH side uses. Can I use that same one for the RH side that only uses one of terminals?
Re: Question on 85 k10 door switches
« Reply #1 on: January 18, 2015, 09:43:51 pm »
what switch window, locks or lights?
« Reply #2 on: January 18, 2015, 10:16:56 pm »
Door jamb switches for the lights sorry
« Reply #3 on: January 18, 2015, 10:29:05 pm »
yes im sure the two terminal one is for the left side to connect to the right. wont do it no harm if only one wire is hooked up. its just cheaper to make one than to make two different styles
« Reply #4 on: January 19, 2015, 02:03:58 pm »
Very true thanks hopfully that fixes my curt lights. Those door jamb switches were pretty rusty.
Offline ackland3
  • Shade Tree Certified Mechanic
« Reply #5 on: January 19, 2015, 09:52:12 pm »
I had a busted wire on mine from the fuse to the dome light in 3 places took forever to track it down. I"d check that too
1985 K10
305
