Author Topic: Starter options  (Read 4508 times)
Offline square81
Starter options
« on: January 21, 2015, 07:24:32 pm »
I'm doing some work over the winter to make my truck a more reliable summer cruiser. I need a new starter. It's been giving me some troubles lately and I'm tired of that. I'd like to upgrade. I seen a post on here about using gear reduction starters instead of the heavy factory ones. One reply I seen used a mid 90's chevy starter. Just wondering if that's a direct bolt on. I know there is 2 ring gear tooth counts. Don't know if that makes a difference or not when using that starter. Any other options or suggestions would be great. Thanks
Re: Starter options
« Reply #1 on: January 21, 2015, 08:03:11 pm »
nothing wrong with oem style. some put a heat shield on it
Offline square81
Re: Starter options
« Reply #2 on: January 21, 2015, 08:30:30 pm »
Oh I know there isn't anything wrong with them. When I replace stuff I try and upgrade if I can. Installed a heat wrap on it already trying to save it. The starter is pretty old and I have headers too. So it's time for a new one.
Offline Shifty
  • I bleed Bowtie red...
Re: Starter options
« Reply #3 on: January 22, 2015, 10:03:05 am »
You can use a Lester #6449, but you'll need a pair of Dorman bolts p/n# 678-107.
You can also use a Hitachi mini-starter, and many different places offer them, Summit, for instance.
98 C2500 ext cab longbed
Offline jaredts
Re: Starter options
« Reply #4 on: January 22, 2015, 07:20:46 pm »
Check out DB electrical starters.
Offline square81
Re: Starter options
« Reply #5 on: January 23, 2015, 08:13:07 pm »
Thanks for the suggestions and part numbers, those help a lot.
