Author Topic: 89 V2500 Single Head light conversion to dual head light question  (Read 4249 times)
Offline bhardy501
I am putting an 89 V2500 back together that was wrecked on the front end. Only sheet metal damage no frame damage. I found a complete front clip from an 85 with dual head lights. What do I need to do to the head lights wired up to work correctly? The front clip has the original wiring that was cut just before the fuse block. I know that the single light has both bright and dim in one light. Can I just separate the wiring from the single headlight connection and rewire it into the to different lights for bright and dim?
Offline jaredts
Re: 89 V2500 Single Head light conversion to dual head light question
« Reply #1 on: January 23, 2015, 08:06:45 am »
Yes, just tap into the high beam positive and the negative from the existing connectors down to the new additional high beam lights.
Offline bhardy501
« Reply #2 on: January 23, 2015, 05:44:58 pm »
OK, thanks. I thought it may work like that. My luck dont usually go that simple though.
Offline timthescarrd
« Reply #3 on: January 23, 2015, 06:40:13 pm »
89 Should have been the newer front style like all the 88-98 trucks, which would have come with side by side dual lights.
On all the dual style truck, low beam was 2 lights on, and high beams were 4 lights on because the lows are dual filament lamps.
