Author Topic: Original frame or not?  (Read 3906 times)
Offline 5l1p5tr3am
« on: January 31, 2015, 04:35:41 am »
Hi friends. So my new '79 project rig is a 4wd but the 2nd digit of my VIN is a C, indicating that it was originally a 2wd. I'm wondering if the body was swapped over to a donor 4wd frame or if the 2wd frame was actually converted. Based on the "interesting" things that have been done to the truck by the POs, nothing would surprise me. Is there any way I can determine whether the frame is original to the truck?  Any help would be appreciated :-)
1979 Chevy Frankenstein
C10 diesel converted to 4x4 with 307/350/203
Re: Original frame or not?
« Reply #1 on: January 31, 2015, 04:56:22 am »
There is a VIN stamped on the frame in various places but if it was converted the front end suspension would be bolted on.  If it is riveted on the frame was most likely changed.  If the cab was changed and the VIN/title was used that would explain it.  How does over the transfer case cab floor look?
« Reply #2 on: January 31, 2015, 05:01:10 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=25239.0 has pictures of a cab floor
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11838.0 identifies cab floors, differences between 2 wheel and 4 wheel drive
« Reply #3 on: January 31, 2015, 05:50:04 am »
what zieg was talking about was all 4x4s have a high hump
2wd have low humps
but as you can see you can also swap the humps over or put a body lift in a 2wd to clear the transfercase.
or your vin could be swapped, usually the dash cluster will have a 4x4 indicator light if its originally a 4x4
« Last Edit: January 31, 2015, 06:00:45 am by Irish_Alley »
Offline 5l1p5tr3am
« Reply #4 on: January 31, 2015, 10:18:03 am »
Great stuff friends; thank you.  I'll go check the hump and the front end to frame attachments and see what's going on.
