Author Topic: Emission controls question for you California folks  (Read 15056 times)
« on: February 21, 2015, 01:59:33 pm »
Here is the deal...  My A.I.R. tube on my 1984 C10 with a 4.1L  I-6 is in need of replacement.  What do you folks in California do when they are no longer available and you can not find a good used ones?  I am facing a rebuild and this one will not come out without crumbling to pieces.
Offline Shifty
  • I bleed Bowtie red...
Re: Emission controls question for you California folks
« Reply #1 on: February 21, 2015, 02:03:49 pm »
Can you fab one?  I don't know the layout of the 6 cylinder ones, but you could probably make one fairly easily...
98 C2500 ext cab longbed
« Reply #2 on: February 21, 2015, 02:07:46 pm »
It is nothing like the V-8 ones.  It would have to be near perfect for the air cleaner housing to go back on it.  This was the last year for the 4.1L and this configuration was not made that long, 1979 I know is different
Offline Shifty
« Reply #3 on: February 21, 2015, 03:25:26 pm »
Any chance of posting a pic?
« Reply #4 on: February 21, 2015, 03:26:04 pm »
i was getting ready to say i have one but its on my 79 4.1. didnt know theyre diffrent
« Reply #5 on: February 21, 2015, 03:43:36 pm »
Here are a few pictures
Offline Shifty
« Reply #6 on: February 21, 2015, 03:57:06 pm »
How's you welding skillz?  You could use the more readily available v8 air tubes, and weld them up.
« Reply #7 on: February 21, 2015, 04:00:24 pm »
zilch, the 2nd picture is where I had to put a 2K epoxy to seal a leak and one of the rear is frozen up.  I soaked for 2 days and it still wants to twist.  Anyone have a 84 book that gives a part # for this?
Offline LTZ C20
« Reply #8 on: February 21, 2015, 07:16:20 pm »
I'm guessing you already checked the junk yards and pull aparts?
LTZ Cheyenne C20
« Reply #9 on: February 21, 2015, 07:32:12 pm »
Use copper tubing
Offline roundhouse
« Reply #10 on: February 21, 2015, 07:33:47 pm »
Is metal brake line the same size ?
« Reply #11 on: February 22, 2015, 08:04:21 pm »
I have put out a WTB post and now know that it is GM part#14077292 that I need.  Thanks for the suggestions, I may be forced to fabricate one since they are no longer available but I will cross that bridge when I have too.
Offline Shifty
« Reply #12 on: February 23, 2015, 12:15:25 pm »
No, the fittings at the manifold are unique to A.I.R. tubes...
I would look for some v8 ones, since they are way more common, and join them with compression fittings if you have to, though brazing would be much cleaner.
Offline roundhouse
« Reply #13 on: February 23, 2015, 09:39:48 pm »
All you need Is for it to look like it works to pass the visual inspection.
« Reply #14 on: February 23, 2015, 10:21:40 pm »
Here in Indiana they don't even open the hood.  What counts is the tailpipe emissions run on a dyno treadmill of sorts.  They inspect the exhaust system, check the gas cap to see it holds pressure and make sure it has a catalytic converter.
