Author Topic: 350/sm465 need some advice  (Read 16800 times)
Offline 78longbed4x4
« on: February 23, 2015, 09:07:01 pm »
Ok guys I'm lookin for a little advice. I just bought an 86 k10, stock 350, sm465 tranny with 208 transfer case and I THINK 3.73 gears with 31/10.5/15's. It's just goin to be a daily driver, nothin special. I drive about 60 miles a day to work and back up and down the good ole Kansas turnpike where the speed limit is 75. I don't really wanna have to turn my engine 3500 RPMs or so to keep up that speed. My question is, would it be worth it to change gears to somethin like 3.08s ? I'm sure bigger tires would help a little too, but it came with brand new 31's on it and I'd hate to put new tires on it already. Would higher gears help or should I just drive her about 65-70 and stay outta the way? Any input would help. Thanks guys
Offline roundhouse
Re: 350/sm465 need some advice
« Reply #1 on: February 23, 2015, 09:37:23 pm »
New tires are a lot cheaper than changing two sets of axle gears
Offline FlatBlack77
« Reply #2 on: February 23, 2015, 10:40:24 pm »
i went from 31s to 33s last year and it only made a few hundred rpm difference at cruising speeds.
you are going to be sucking alot more gas once you get up to those speeds anyway. if i was you i would stay around 60-65 in the slow lane. you are going to be saving alot of gas money rather than spending alot of money just to get somewhere quicker.
these trucks are like barn doors in the aerodynamics department
Offline MannyDantyla
  • '83 k10, 350 sbc, sm465, np205
    • dannix.net
« Reply #3 on: February 23, 2015, 11:46:31 pm »
Where in kansas do you live?? I live in Lawrence.
I'll trade you axles. I have a 3.42 gear ratio. 10 bolt GM rear axle and 10 bolt font axle. I drove from Lawrence to Wichita a few weeks ago and was cruzing at 65-70 no problem.
The reason I want to new axles is I need a higher gear ratio because I have 35" tires. Let me know if this is an option you would want to explore.
Offline enaberif
« Reply #4 on: February 24, 2015, 01:15:33 pm »
I wouldn't be thinking I'd be looking at your gear ratio and seeing what you have.
    • dannix.net
« Reply #5 on: February 24, 2015, 03:26:22 pm »
You can calculate the ratio by turning the wheel and watching how many times the axle spins.
  • Chalk the front wheels and make the sure you're doing this on a flat surface. This is very important because the parking brake to the rear won't stop the front from rolling.
  • Put it in neutral and disengage the parking break.
  • Lift the rear end up with a floor jack on the diff pumpkin. If you have an open differential, you must keep one wheel on the ground. You can know it's an open diff because, with both wheels in the air, if you turn one wheel the other wheel will turn in the opposite direction.
  • If you do have an open differential, you'll have to put one wheel back onto the ground.
  • Place your floorjacks under the axle for safety. Don't forget to chalk the front tires.
  • Rotate the wheel 360 degrees and watch very closely how many times the axle rotates.
Here are the calculations:
Wheels Spin in the SAME direction.
A hair over 2 1/2 times or 2.5 times, then safe to say ratio is 2.56:1
A hair under 2 3/4 times or 2.75 times, then safe to say ratio is 2.73:1
A bit over 3 times, then safe to say ratio is 3.08 or 3.07:1
A hair under 3 1/2 or 3.5 times, = 3.42:1
A hair over 3 1/2 or 3.5 times, = 3.54 or 3.55:1
A hair under 3 3/4 or 3.75 times = 3.73:1
A bit over 4 times = 4.10 or 4.11:1
A hair over 4 1/2 or 4.5 times = 4.56 or 4.57:1
A bit under 5 times = 4.88:1
A bit over 5 times = 5.13:1
Wheels Spin in the OPPOSITE direction.
A hair over 1 1/4 times or 1.25 times, x2 then safe to say ratio is 2.56:1
A bit over 1 1/3 times or 1.33 times, x2 then safe to say ratio is 2.73:1
A bit over 1 1/2 or 1.5 times, x2 the safe to say ratio is 3.08 or 3.07:1
A bit under 1 3/4 or 1.75 times, x2 = 3.42:1
A hair over 1 3/4 or 1.75 times, x2 = 3.54 or 3.55:1
A heavy bit under 2 times x2 times = 3.73:1
A bit over 2 times x2= 4.10 or 4.11:1
A hair over 2 1/4 or 2.25 times x2= 4.56 or 4.57:1
A bit under 2 1/2 or 2.5 times x2 = 4.88:1
A bit over 2 1/2 or 2.5 times x2 = 5.13:1
I copy & pasted some of this info from gmsquarebody.com - full instructions here: http://www.gmsquarebody.com/forum/showthread.php?t=3860
« Reply #6 on: February 24, 2015, 10:01:20 pm »
Ok I'll do that this weekend and see exactly what I have
« Reply #7 on: March 01, 2015, 04:04:51 pm »
So I checked into what gears I have and it looks like they're 3.73s....I bought the truck from a guy I work with and he said he has a set of 2.73s that he'll give to me. Also I've decided to go to 33" tires so that should put me somewhere around 2000-2300 rpm at 70 or so, so that should be plenty good for highway drivin. Thanks for the help guys
Offline roundhouse
« Reply #8 on: March 01, 2015, 07:18:56 pm »
2.73 and 33"s is gonna be a slow start off. But with a 465 you're not going any where in a hurry no matter what gear or Tires you have
We have 3.73 and 35"s and it's just about right
Wish they were 4.11
« Reply #9 on: March 01, 2015, 09:26:12 pm »
Yeah I fugured the granny low would finally come in handy....I'll let y'all know how it works out....probably gonna do the gear swap after work this week sometime
    • dannix.net
« Reply #10 on: March 02, 2015, 01:01:49 pm »
33" tires with 2.73 gears? Hope you're in the flat part of Kansas!
Also, I don't think the granny gear is syncronized. It's not meant to be used as the 1st gear. Correct me if I'm wrong.
Offline ehjorten
« Reply #11 on: March 02, 2015, 01:13:12 pm »
With your TH350, 3.73:1 Rear Gears and 31" tires you should see about 3,100 RPMs at 75 MPH.
With 33" tires and 2.73:1 gears you would see about 2,100 RPMs at 75 MPH.  That is about what I pull in OD with 4.10:1 rear gears and 35" tall tires.  It is awfully comfy at 75!
« Last Edit: March 02, 2015, 01:20:32 pm by ehjorten »
-Erik-
    • dannix.net
« Reply #12 on: March 02, 2015, 02:54:26 pm »
I bet it is, but you have 3 or 4 gears to get to that OD.
I have a sm365, 35" tires and 3.42 gears. And let me tell you, driving around town SUCKS! It's a dog up hill, and there's a lot of little hills where I live, lol. I'm working on the engine performance, but I need smaller tires or bigger gears lol
Offline roundhouse
« Reply #13 on: March 02, 2015, 05:15:21 pm »
It's the transmission
We have 3.73. 35" tires and  just swapped in a NV 3500 5 speed and it's light years better than the 465 even though around town you don't get to use the OD 5th
Offline overtime
« Reply #14 on: March 06, 2015, 07:42:28 am »
Go to 4low.com it has a calculator to help you figure out the best setup for what you want.
