Author Topic: Help with my block code  (Read 2671 times)
Offline ian75c10
    • Art Dir / Designer Ian Goolsby
« on: March 03, 2015, 10:41:53 pm »
Hi guys I am finding more out about my engine. I have a 75 c10 but the engine is a 327 ( punched to 331 ) I believe its a 1967 block. I got the number from the block but couldn't read the date code. the number is 3892657. I do know I haave the camel hump heads that DO NOT have the accessory bolt holes so i think they are the earlier ones. I'll get the numbers next week when I get the new valve cover gaskets in. Anyways in my attempt to learn more I am reading about lots of guys that get the large journal 327 engine and push them out to 350 with ease. Do i qualify to attempt this with this block and these heads? I am also reading that I may need hardened valve seats inside of heads for modern unleaded gas? Any thoughts or guidance would be appreciated. thanks
Re: Help with my block code
« Reply #1 on: March 03, 2015, 10:53:09 pm »
1967 Block.  Get the numbers on the front of the block to find out for sure.  That block casting was for 302, 327 and 350
