Author Topic: looking for suggestions on my setup  (Read 5862 times)
Offline rwilliamz
« on: March 06, 2015, 03:16:52 pm »
hey guys im looking for suggestions on what I should do with my 83 c10 swb stepside
im running a built 350 and a sm465 now but am considering a swap to a 5 speed or an auto tranny.
the engine makes good power and I am putting in a positrac in the rear.
I like to have fun with the truck so I don't want to put in anything weak if I do a swap.
My 465 is in need of some help, the syncros are beat, clutch is old, the manual linkage is worn and im not sure if I should rebuild or swap
What do you guys suggest?
thanks for any input or suggestions
Re: looking for suggestions on my setup
« Reply #1 on: March 06, 2015, 03:37:57 pm »
Since you have the high hump cab there is no problem going with any transmission.  The NV4500 is a good choice or a TKO http://www.5speedtransmissions.com/68-87_chev_truck_5sp.html
A great upgrade to a juice clutch set up would be good at this time as well
Offline roundhouse
« Reply #2 on: March 08, 2015, 10:36:23 am »
NV 3500 5 speed from 97-07 silverado is a good swap
« Reply #3 on: March 08, 2015, 10:58:43 am »
4L60/700R4 would be a nice upgrade. Sell the MT linkage, pedals and accessories to help fund the conversion.
Offline rwilliamz
« Reply #4 on: March 08, 2015, 02:29:59 pm »
what will I need to upgrade to a hydraulic clutch if I decide to do a 5 speed swap.
a buddy of mine has a parts 94 chevy shorty with a 4.3 and a 5 speed that im looking to pull the tranny out of.  can I use anything else from this truck to help with a swap?
what year trucks should I be looking to scavenge parts from?
Offline roundhouse
« Reply #5 on: March 08, 2015, 10:38:04 pm »
The 97-07 trans are better but that should wor
The external slave will hit the front driveshaft if it's 4wd
You need a Hudrualic clutch and brake pedal setup from a 85-87 pickup And have a hose made at a local shop
Offline rwilliamz
« Reply #6 on: May 09, 2015, 02:28:22 pm »
so I have decided I want to do an auto swap.  im thinking about a 4l60 or a 700r.
What do you guys think is the better choice?
Also, correct me if im wrong but I will need the following parts:
tranny, flex plate, convertor,
cooler lines and cooler (because my rad does not have trans cooler),
a driveshaft and maybe a new yoke
kickdown cables and brackets.
and some sort of floor shifter (I don't want to changer columns)
and automatic pedal setup
What do I do about the neutral safety switch off the clutch pedal?
Offline FlatBlack77
« Reply #7 on: May 10, 2015, 09:25:11 am »
youll probably need a different speedometer cable
you shouldnt need an automatic pedal setup unless you want that wide brake pedal.
youll need the dipstick tube. one with the tab that uses the transmission-to-engine mounting bolt to hold it in place is the best
Offline LTZ C20
« Reply #8 on: May 10, 2015, 09:53:28 am »
Also, depending on the year of the transmission, a 4L60 and a 700R are one in the same transmission.
LTZ Cheyenne C20
Offline FlatBlack77
« Reply #9 on: May 10, 2015, 05:04:18 pm »
and watch out for lockup vs non lockup transmissions
