Author Topic: Power steering line  (Read 10533 times)
Offline N8thegr8
Power steering line
« on: March 10, 2015, 09:16:29 am »
Replacing my high pressure line. I've had trouble in the past with a leak where it goes into the pump. I don't want to strip the threads. Heard plumbing tape isn't a good idea on high pressure hydrolic lines.  Pipe dope? Ideas?  Thanks! It's a new pump and not cross threaded.
Re: Power steering line
« Reply #1 on: March 10, 2015, 10:10:18 am »
With the o-ring newer style you shouldn't have an issue.  Something is nicked if it leaks, the 37 degree taper (older style) or the o-ring (newer style) is the sealing contact area not the threads.
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: March 10, 2015, 10:12:23 am »
My money is on Permatex p/n# 54540
98 C2500 ext cab longbed
Offline enaberif
« Reply #3 on: March 10, 2015, 03:17:12 pm »
Just replaced the high pressure hose in my truck and was the non oring style and it doesn't leak at all and I didn't use any tape or dope.
Just snug em up and they shouldn't leak at all.
Offline N8thegr8
« Reply #4 on: March 10, 2015, 05:10:03 pm »
Almost want a tee shirt saying I drove this rig without power steering :) new line is in.. correctly this time... With O rings in place. It's kinda close to the exhaust mani. . Wonder if anyone has ever put a cooler in.
Offline Shifty
« Reply #5 on: March 10, 2015, 06:52:02 pm »
Maybe pick up heat sleeving....
Offline LTZ C20
« Reply #6 on: March 10, 2015, 07:11:03 pm »
You could pick up an auxiliary transmission cooler and use it as a power steering cooler. They are pretty cheap and available at most auto parts stores. Automatic transmission fluid and power steering fluid are both basically detergent hydraulic fluids. Infact lots of GM vehicles use auto trans fluid in the power steering fluid system, I do this as well. Reason being that it has higher heat capabilities and is a little tougher due to the pressures and forces a transmission usually endures that most power steering systems wouldn't see.
« Last Edit: March 10, 2015, 07:12:36 pm by LTZ C20 »
LTZ Cheyenne C20
Offline enaberif
« Reply #7 on: March 10, 2015, 08:57:25 pm »
If its close to the exhaust mani your possibly have your lines running the wrong way.
« Reply #8 on: March 10, 2015, 09:33:36 pm »
As LTZ stated any fluid cooler will work.  This is a factory power steering cooler from the 80's models
Offline LTZ C20
« Reply #9 on: March 11, 2015, 01:22:53 am »
That thing looks like the inside of my toaster hahaha.
LTZ Cheyenne C20
Offline N8thegr8
« Reply #10 on: March 11, 2015, 07:07:39 am »
Hmm... bend up some tubing.. Lil rubber and some clamps?
Offline enaberif
« Reply #11 on: March 11, 2015, 08:12:11 am »
Bubble flare the lines for the hoses and you'll be good.
« Reply #12 on: March 11, 2015, 07:52:04 pm »
Teflon tape & pipe dope are only for when the threads are used to seal. Such as pipe threads. As far as the cooler lines go, you will need to use hydraulic return hose. Don't use fuel line.
Offline N8thegr8
« Reply #13 on: March 12, 2015, 01:53:19 pm »
Thanks for all of the replies!
