Author Topic: marker light trouble  (Read 4993 times)
Offline CarlBengston
« on: March 13, 2015, 02:12:16 pm »
I've got a new light problem. My headlights/brake lights/blinkers work but none of the marker lights come on when I pull the switch. Is there a common fuse for these? Circuits 9/40/44
Re: marker light trouble
« Reply #1 on: March 13, 2015, 02:39:28 pm »
So I don't have power at the t/l ctsy fuse or the instrument light fuses. I have power going into my light switch but not leaving through the dark green/brown/orange wires. It's a new switch
« Reply #2 on: March 13, 2015, 06:24:06 pm »
« Reply #3 on: March 16, 2015, 06:57:19 am »
1983 k10 350/700r4
« Reply #4 on: March 16, 2015, 12:38:35 pm »
Have you looked at the wiring schematics in the Tech section?  Have you checked all your bulbs? Checked for power at the socket at the bulbs?
« Reply #5 on: March 16, 2015, 04:29:14 pm »
I've run through all the wiring diagrams. Checked bulbs/housings. I'm not getting power that far. I've got power from the red wire running into the headlight switch. But only the yellow wire coming out has power. The green/orange/brown that run the marker lights don't have power. But it's a new switch.
« Reply #6 on: March 17, 2015, 09:08:06 pm »
So you have power coming out of the switch?  But not at the socket?
« Reply #7 on: March 19, 2015, 07:24:51 pm »
I only have power out of the switch to the headlights. No power to the rest of the lights
