Author Topic: How do i fix this Leak?  (Read 3462 times)
Offline Thundergun
« on: March 19, 2015, 10:16:44 pm »
Hey all. Well im finally getting around to fixing a lot on my k10.
So the transfer case appears to be leaking where the front drive shaft connects. See photo.
Is there a seal here that i need to replace? Anyone have a PN for it? I called autozone earlier and told them i needed said seal and i swear that they had no idea what i was talking about. She asked me 4 or 5 times if it was a V8 or V6.
Pretty sure the tag says it's a 208C transfer case.
Thanks everyone.
1985 K10 Shortbed, 6" Superlift, 33x12.5x15" tires, 100% bad, '87 fuel injected 350 (i think)
Offline Thundergun
Re: How do i fix this Leak?
« Reply #2 on: March 20, 2015, 10:59:53 am »
http://www.autozone.com/drivetrain/transfer-case-seal/duralast-transfer-case-seal-/chevrolet/v10-1-2-ton-p-u-4wd/1987/8-cylinders-k-5-7l-tbi/12019_0_0_5164/
Thank you very much. that is def not the part they almost sold me. I guess i could have tried to check the website myself first ...
Any tricks to installing it? I imagine i remove the drive shaft from the front dif. Then from the transfercase. Then i should be able to swap the seal.
Thanks again.
« Reply #3 on: March 20, 2015, 10:55:19 pm »
yeah its not too hard, just like replacing a seal on the transmission rear
