Author Topic: No power to fuel pump.  (Read 5945 times)
Offline thelincolnguy
« on: April 01, 2015, 08:09:07 pm »
So, i recently had my 1989 chevy 3500 1 ton square body dually delivered. Have had fuel delivery problems since i bought it. Purchased it around 6 months ago for a good price with an agreement of the fuel pump being bad. So, i replaced the pump, sending unit, and i also ran longer lines and wires so i could hook the tank up while it was low enough to fit my arm between it and the floorboard. Started it up and ran like a charm aside from having to start it with brake cleaner a few times. Also, it is TBI. Like i said, i had it delivered the other day, drove it off the trailer into my driveway. Went to start it up, no good. used brake cleaner with no luck. Just runs until its out of brake cleaner. So, i dropped the fuel tank, warrantied the pump, and now im not getting power to it. Ran a brand new ground. Replaced underhood relay. All fuses good. Cannot find any other fuses or relays. The fuel gauge works fine. I was wondering if running a brand new constant wire to the fuel pump to a switch under the dash would work. Just cut it on when i start it. Its nearly impossible to trace the factory wires.
Thelincolnguy
Re: No power to fuel pump.
« Reply #1 on: April 01, 2015, 10:00:41 pm »
Is the relay on the firewall any good?  It it switching on?  Can you apply 12V to the test wire and the pump come one?  Does it have the fuel Module on it?
This is a recent topic on fuel pump/wiring: http://forum.73-87chevytrucks.com/smforum/index.php?topic=30539
« Reply #2 on: April 02, 2015, 01:10:17 am »
also
check your "ecm b" fuse
« Reply #3 on: April 02, 2015, 01:13:09 am »
but even with a bad fuel pump relay the oil pressure switch should kick in once the oil pressure is built to 3 psi and and it will power the fuel pump. do you have dual tanks?
« Reply #4 on: October 19, 2015, 04:32:14 pm »
yes i have dual tanks. but the passenger side is dead. and i ran a wire from the relay to the pump and it has worked seamlessly. thanks!!
Thelincolnguy
« Reply #5 on: October 19, 2015, 09:07:37 pm »
Could be the fuel tank selector switch
