Author Topic: 77 Horn button chalky  (Read 6988 times)
Offline Man With A Gun
« on: April 04, 2015, 03:29:44 pm »
I cleaned the stickiness off the steering wheel with some 3M adhesive remover. It cleaned up pretty well but the horn button looks kind of chalky. I guess its made of a different material than the rest of the steering wheel.
From the photos I've seen this is a common problem.
Short of painting the wheel and the horn button, is there a product that will clean the chalkiness away?
Will Armor-All or a Meguiar's product work?
Offline FlatBlack77
Re: 77 Horn button chalky
« Reply #1 on: April 04, 2015, 05:14:29 pm »
you could try some kind of amour all or something along those lines. but dont get your hopes up. its probably just the plastic deteriorating from years of being in the sun and heat.
« Reply #2 on: April 05, 2015, 06:22:35 pm »
Found this product on the other forum.
Anyone used it?
http://67-72chevytrucks.com/vboard/showthread.php?t=634412
Offline roger97338
« Reply #3 on: April 21, 2015, 10:18:20 am »
You could try some "back to black." It's made for black exterior moulding.
Offline The Count
« Reply #4 on: May 14, 2015, 09:55:07 am »
My 77 GMC's horn looked like that.  Nothing I put on it made much of a difference.  So I busted out the Novus 2 plastic polish (available at Amazon, impossible to find locally) and a microfiber cloth.  Polished the heck out of it after taking the center badge out.  It looked alot better when I was done but not perfect.  I followed the polishing with a couple applications of 303 Aerospace Protectant (also available at Amazon).  I almost perfectly matched the wheel after that.
