Author Topic: 79 c10 radiator inlet/outlet size  (Read 2635 times)
Offline vr4oaks
« on: April 12, 2015, 12:06:26 pm »
Does anyone know the size of the inlet/outlet of a standard 350 radiator and are the 454 the same inlet/outlet size? Eventually I'm wanting to redo my coolant piping.
-vr4oaks
1979 Chevy c10, Super HX30, POD Injectors, Timing and Fuel turned up, FASS 15 PSI Fuel Pump, BHAF, Autometer Pro-Comp 2 Boost and EGT gauges, 4" MBRP Dodge Cummins Exhaust, 12" 273 welded rear-end, max boost 40 pounds, max EGTs 1500, Hydroboost
