Author Topic: which tailstock do i need  (Read 5115 times)
Offline londonstu
« on: April 22, 2015, 08:53:51 pm »
I'm changing from a 250 with a 3speed manual to a 327 with a 350 auto in an 80 c10. is it a straight bolt in and which length tailstock do I need ?  thanks, Stu
Re: which tailstock do i need
« Reply #1 on: April 22, 2015, 10:43:29 pm »
a little help with translation, by tail stock you talking about the driveshaft or driveshaft yoke or you talking about the transmissions outputshaft length?
Offline londonstu
« Reply #2 on: April 25, 2015, 04:13:20 pm »
           Sorry about the terminology ,I'm referring to the transmission output shaft length. Thanks,  Stu
« Reply #3 on: April 25, 2015, 11:03:48 pm »
the output shaft doesnt matter you just need the proper length drive shaft to fit. you also might need a new cross member from the th350. is this coming out of a truck or car
Offline londonstu
« Reply #4 on: April 26, 2015, 06:39:13 pm »
Irish.... My truck is a1980 c10. I have the 327 already,but don't have the tranny yet. I was hoping to use the same two piece driveshaft that is in the truck and purchase a transmission that fits. Thanks for your help .   Stu
« Reply #5 on: April 26, 2015, 07:31:33 pm »
If you still have the driveshaft from the 3 speed manual, assuming originally a 3 speed on the column, a short tailshaft TH350 will work.
« Reply #6 on: April 27, 2015, 08:32:00 am »
zieg,  whats the size on the 3 speed? this is different than the 465 right?
Offline londonstu
« Reply #7 on: April 28, 2015, 08:24:51 pm »
Thanks for the info guys. The truck is original right now with the 3 on the tree, so I'll be looking for a short tail TH350  . Hopefully all goes right.
