Author Topic: 1997 305 vortec needs put in time  (Read 3283 times)
Offline 1973chevyk10
« on: May 02, 2015, 10:39:23 pm »
I've tried and tried several times today to get these bad boy back in time and I have not had any luck. I get #1 at tDC on compression stroke and line my rotor button up with #1 plug tower and still no start. Any help grately appreciated need to get this going its my only vehicle
Offline csdineley
Re: 1997 305 vortec needs put in time
« Reply #1 on: May 02, 2015, 11:17:42 pm »
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Offline roundhouse
« Reply #2 on: May 04, 2015, 07:44:45 am »
You getting pops?
May be 180 degrees out
We had to take an old dizzy cap and cut out the center so we could actually see where the rotor was pointing
Then we lined up the timing mark on the crank pulley at 0
Looked thru the hole in the cap to make sure rotor was pointing at #1 when the dizzy was seated in
Sometimes you have to have someone turn the dizzy back and forth slowly when cranking to get it to crank
Its off more than you think
Then i set the timing. By ear listening for knock going up a hill full throttle or with a vacuum gauge
