Author Topic: 73 C20 Performance Engine Build  (Read 102721 times)
Offline LTZ C20
Re: 73 C20 Performance Engine Build
« Reply #120 on: June 01, 2015, 08:12:21 pm »
Oil leaks aside and all...
WHAT IN THE NAME OF THE GREAT SCOTT IS THIS CRAP!?!?
LTZ Cheyenne C20
« Reply #121 on: June 01, 2015, 10:10:50 pm »
OUCH!!!  That's a bummer LTZ!   :(
A little more information, if you please...
Describe the metallic looking trash huddling around that center head bolt.  Have you determined exactly where it came from?  More questions: ( 1 ) What are the valve retainers-to-rocker arms clearances?  ( 2 ) How high did you rev the engine (be honest)?  ( 3 ) Are any of the pushrods bent?  ( 4 ) Are the valve springs correctly matched to the cam?  ( 5 ) Did you check for coil and retainer bind during setup?  ( 6 ) The valve train geometry appears "off" (as in way off center) - did you check rocker sweep across the valve tip with a dial indicator and dye to optimize pushrod length?  ( 7 ) What was the oil pressure running?  ( 8 ) Was the top end adequately pre-lubed during assembly?  ( 9 ) Did you align the pushrods and check the torque on the rocker studs during assembly?
Offline LTZ C20
« Reply #122 on: June 02, 2015, 01:44:54 am »
Metallic looking trash is some Permatex Right Stuff that came apart when I pulled the cover off.
1- um not sure?? Would this be lash?
2- honestly, highest it's been is 3500, one time. Under normal driving, 3000.
3- nope :) not even that 1.
4- yes, verified by summit racing technical assistance
5- do you mean coil spring and valve retainer bind? If so then no, heads came pre-assembled
6- umm kinda sorta. I found proper pushrod length by following the steps outlined in the summit quick flicks instructional video on finding pushrod length.
7- about 60 psi
8- yes
9- not sure what align the rods means, align them with what? Check torque on studs, no. Was I supposed too?
This is only my second engine so I'm sure that I may have missed a few things. I know I learned way more the second time then I did the first time.
I think that, in my limited knowledge, the rocker arm nut just came loose. I researched this and it appears, based on what I saw, the crimp on the nut lost its hold and the nut rattled loose. It did not ruin or damage anything, just ran like it w as missing a cylinder. I got it fixed tho, went to auto parts store, picked up 6 extra nuts ( all they had in stock, .99 cents a piece), also got new gaskets and some more Right Stuff. No broken or busted parts found, all checked out good. Reassembled, rotated engine over and set proper lash, put it all together. So far no leaks (Knock on wood) and running great, like it never happened.
LTZ Cheyenne C20
Offline rich weyand
« Reply #123 on: June 02, 2015, 02:02:24 am »
Did you check the pushrod for straight?  Easiest is to roll it across a flat surface....
Offline LTZ C20
« Reply #124 on: June 02, 2015, 08:08:48 am »
Yep, it's good.
LTZ Cheyenne C20
Offline enaberif
« Reply #125 on: June 02, 2015, 08:48:26 am »
Holy geezus I'd be replacing all those nuts just for peace of mind! That is nuts.
Offline enaberif
« Reply #126 on: June 02, 2015, 08:49:39 am »
Aligning push rod to rocker simply means ensuring the ball on the pushrod sits in the cup on the rocker.
Offline LTZ C20
« Reply #127 on: June 02, 2015, 09:24:24 am »
I was goin to but didn't have the time or enough nuts. Parts store only had 6 so I just did the 1 that came loose. I did not see any evidence of others coming loose. Plus I gotta be able to drive this every day.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #128 on: June 02, 2015, 09:25:21 am »
Oh ok. Yea did that.
LTZ Cheyenne C20
« Reply #129 on: June 02, 2015, 09:30:27 am »
Good to hear it's that simple.  Your opening comment combined with reflections off the oil coating the retainers and debris implied something more serious.  Good joke, LTZ!  You had me questioning whether the spring retainers had actually hit the bottoms of the rockers, even though your valvetrain combination is very conservative.  lol
Just to settle two questions that I raised (not necessarily something you need to do):  (1) A little graphite spray or Prussian blue lightly smeared on the valve tip will wipe away as the rocker moves through its full range of motion.  The resulting witness mark should be centered across the valve tip.  This verifies whether the pushrod length is correct.  (2) pushrod guide plates typically can be adjusted laterally for best alignment of the rockers to the valve tips while preventing the pushrods from dragging the head casting.  It's a limited adjustment that already may be near perfect from the manufacturer.  Double checking rocker stud torque is good practice and often recommended by head manufacturers.
I agree with replacing all the nuts.  Why run the risk of taking it apart again?
Offline LTZ C20
« Reply #130 on: June 02, 2015, 09:41:35 am »
Ok. I understand. I will have to find some more nuts first. I would like to be able to go a week or so without having to touch that engine. I guess we will wait and see.
LTZ Cheyenne C20
Offline enaberif
« Reply #131 on: June 02, 2015, 10:30:43 am »
Well I want you to think of it this way. This time you were lucky and didn't damage anything. The next time you could take out a rocker, pushrod and maybe a lifter. Willing to take that chance?
Offline LTZ C20
« Reply #132 on: June 02, 2015, 11:20:59 am »
Ummmm no.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #133 on: June 17, 2015, 11:30:44 am »
I'm happy to report that the truck has been running good and all is well, knock on wood lol.
LTZ Cheyenne C20
Offline fitz
« Reply #134 on: June 21, 2015, 05:35:49 pm »
Still running good?
