Author Topic: 1977 2wd 350 oil pan removal  (Read 7173 times)
Offline jg1977c20
« on: May 04, 2015, 05:57:25 pm »
so i have a 1977 c20 cheyenne with a 350  (2wd)   it looks like theres a ton of room there to drop the oil pan without lifting the motor -does that sound right ?
1977 c20 cheyenne camper special 8200gvw
Offline FlatBlack77
Re: 1977 2wd 350 oil pan removal
« Reply #1 on: May 04, 2015, 06:11:03 pm »
my 77 c10 looks the same way. but im pretty sure the pan wouldnt clear the oil pump/pickup without raising the engine a little bit.
on a side note i assume you are planning to replace the pan gasket. i recommend a one piece Felpro. its the one i went with after quite a bit of researching. it even came with those little clip things to hold the gasket and pan in place
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #2 on: May 04, 2015, 07:23:47 pm »
Dropping the pan is super easy - you don't have to raise nuthin'.
+1 on the 1-piece pan gasket.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline jg1977c20
« Reply #3 on: May 04, 2015, 07:37:02 pm »
awesome - a couple of people said the same and looking under there it seemed it would come out without raising the motor  and yes i will go for the 1 piece gasket - thats a good note - last oil pan gasket i did was on a 77 olds  of course i had to lift the motor on that one and the multi piece gasket was a pain  glad they came out with the 1 piece since .
« Last Edit: May 04, 2015, 08:27:44 pm by bd »
Offline FlatBlack77
« Reply #4 on: May 05, 2015, 02:57:34 pm »
good to know!
