Author Topic: I want faster  (Read 6694 times)
Offline 454c10
I want faster
« on: May 26, 2015, 03:45:57 pm »
Ok so my 1986 gmc c10 short bed ran a 15.1 with a stock 454 big block its got headers wieand intake and edelbrock carb i want in the mid 14s with out dumping alot cash i live in higher altitude and its got 2:73 gears posi axle what yall think i could do thats easy????
Re: I want faster
« Reply #1 on: May 26, 2015, 03:48:25 pm »
3.08 or 3.42 gears
Offline fxrsrider
  • '75 C10, 385ci, TH350, Positraction, 5" drop
    • pauldemarcostudios.com
Re: I want faster
« Reply #2 on: May 26, 2015, 04:25:56 pm »
you will get gains both by taking the choke out of the carb and with ram air.
« Last Edit: May 26, 2015, 04:28:20 pm by fxrsrider »
Offline Kren420
  • 1986 C10 Silverado
Re: I want faster
« Reply #3 on: May 26, 2015, 07:04:19 pm »
I definitely second swapping out the gears.
Offline FlatBlack77
Re: I want faster
« Reply #4 on: May 26, 2015, 10:39:47 pm »
rear gears.
what kinda tires you running?
Offline 454c10
Re: I want faster
« Reply #5 on: May 27, 2015, 11:06:15 pm »
I got 373s from my uncle and i ran slicks for tires
Offline 78BIG-TEN
Re: I want faster
« Reply #6 on: May 28, 2015, 10:15:23 am »
Definitely go with a gear swap.Assuming you have a TH400 behind that BB 3,73 might be
a little steep for highway use,depending on what tire you are using.3.08 with a 28 inch
tire had me around 2600 at 70.If you are running a tall tire like 31.50's,you could go to
a wider lower profile tire simulating a gear change.Next I would do a cam swap,biggest
bang for the buck in my opinion
Offline 454c10
Re: I want faster
« Reply #7 on: May 28, 2015, 10:41:18 am »
Will do thanks for your time
Offline Stewart G Griffin
Re: I want faster
« Reply #8 on: June 01, 2015, 08:11:15 pm »
Then nitrous.
