Author Topic: think I have a misfire  (Read 11927 times)
Offline English
Re: think I have a misfire
« Reply #15 on: June 03, 2015, 04:35:43 am »
Managed to find a place near me that does both compression and leakdown tests, it's booked in for Friday.
Movement on the balancer is only visible with the timing light hooked up to cylinders 5 (wanders) and 7 (slight wobble) all other cylinders show a rock steady balancer.
I've made sure the spark leads for 5 & 7 do not cross.
I'm wondering if the movement seen in the balancer is a result of bad firing due to sticky valves, or a result of the spark occuring at the wrong point because of a timing issue (chain? old distributor?); but if it was timing, wouldn't all cylinders be affected?
Offline enaberif
« Reply #16 on: June 03, 2015, 06:32:00 am »
How many miles on the motor? And do you know if the chain has ever been done?
Offline English
« Reply #17 on: June 03, 2015, 02:52:36 pm »
Odo wasn't working when I bought it, and it's not the original engine, so very much an unknown. Plus it's an import with virtually no history!
Offline enaberif
« Reply #18 on: June 03, 2015, 03:53:38 pm »
Well I would get the two tests done then I would visually inspect the harmonic balancer and see if the rubber is cracked or in bad shape.
From there I would possibly think about a timing chain change.
« Reply #19 on: June 03, 2015, 04:53:04 pm »
You can easily check the balancer and timing chain yourself with minimal tools:
Offline English
« Reply #20 on: June 06, 2015, 07:17:55 am »
Picked the truck up from the garage yesterday. They did both compression and leakdown tests, and the verdict is that I have a leak between cylinders 3,5 and 7. The other head is fine.
Bad news on the one hand, but at least I have a verdict now, instead of chasing my tail trying to work out what's wrong. And it ties in with what I've been experiencing and what I've found with the timing light and vacuum gauge, so I don't think they're trying to mug me off- always a worry when going to a new garage (my regular guy retired last week).
So it's either the head gasket or a cracked head. To find out they need to start stripping down, which means it's time to spend money. Or... I asked about getting a long block and swapping that in instead, and to my surprise they said the labour cost would probably be the same! I am SERIOUSLY considering this as an option now.
Offline roundhouse
« Reply #21 on: June 07, 2015, 05:42:52 pm »
I would just swap
In a new engine
We are going to do this also
Ours has a wiped lobe on the cam and a couple other issues and we are planning on swapping in a LS engine
Guy near me sells LS engines with the wiring harness and modified computer.   Ready to run , for $1100
Offline philo_beddoe
  • 77 C-10
« Reply #22 on: June 12, 2015, 07:00:49 pm »
In general, how do you know if you have a misfire?
