Author Topic: Modest not Outrageous Headlight Upgrade  (Read 51626 times)
Re: Modest not Outrageous Headlight Upgrade
« Reply #15 on: June 17, 2015, 11:32:11 am »
when i went on painless's website it only list one wire harness for our trucks. but as i just found out 84 and 91 use two different fire wall connections. so it appears i couldnt use it without replacing all my wires and i dont know if any other truck connections are different.
Offline enaberif
« Reply #16 on: June 17, 2015, 12:29:05 pm »
People over complicate wiring. In some situations yes its very difficult and may take a bit to understand. But automotive wiring is so simple and easy that if you just stop to think you can do it.
Doing a headlight harness upgrade is dead simple and so easy to make it your own. For example with relays you could make it so that both headlights are run apart from each other so that if you lose power to one side the other still works.
Offline pneuner750
« Reply #17 on: June 17, 2015, 01:13:21 pm »
Look at jw speaker! They are very expensive. It might give you a ideas
Sent from my SM-G900V using Tapatalk
Offline LTZ C20
« Reply #18 on: June 17, 2015, 01:56:29 pm »
I think harness plugs into the head light sockets, not the firewall. The 84 and 91 setups my be different the and 80 and older.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #19 on: June 17, 2015, 01:58:09 pm »
I know. I can do it, just don't FEEL like it. I believe that the harness is designed to work so that they are independent lights in a power or bulb failure event.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #20 on: June 17, 2015, 01:58:32 pm »
I'll check it out thanks.
LTZ Cheyenne C20
Offline kuhnzoo
« Reply #21 on: June 18, 2015, 09:54:42 pm »
Used Cibies with Osram bulbs from danielster.com for my 85 K10. Have not re-wired with relays yet, but the light output is so much better than the standard halogen sealed beams!
Sent from my MB520 using Tapatalk 2
1985 K10 350CID A/T
Offline LTZ C20
« Reply #22 on: June 19, 2015, 12:26:25 am »
Thanks I'll check this out too.
LTZ Cheyenne C20
Offline KWKENUF
« Reply #23 on: June 24, 2015, 11:14:58 am »
I did my '79 last year and used Hella E-code H4 lights.  That is a popular upgrade for Jeep guys.  I also installed a pre-made relay harness,  but I do not remember from who off the top my head.  At the end of the day I think I spent a touch over $100 total.  The difference is amazing even with the 55/60 watt bulbs that come with them.
Offline LTZ C20
« Reply #24 on: June 24, 2015, 11:34:55 am »
Thanks, 1 more setup to check into.
LTZ Cheyenne C20
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #25 on: July 14, 2015, 02:18:45 pm »
I did the same setup but i got the DOT version.  night and day difference.  the glass is a whole lot clearer than the sealed beams.
  • Z62 ON-ROAD
« Reply #26 on: July 14, 2015, 02:33:18 pm »
A few pics of my setup.
Both lights and upgraded bulbs were about $120.  the H3's are for the driving lights under the bumper.
My Relay harnes with relay for high and low beam
Hellas Super clear lens
Hellas lit up with relays
Low beams
High beams without driving light
this ones high beams WITH driving lights on.  I have them setup aimed higher and wider than normal, since they only come on with the high beams, they are just auxiliary high beams actually.
« Last Edit: July 14, 2015, 02:44:39 pm by 78 Chevyrado »
Offline LTZ C20
« Reply #27 on: July 15, 2015, 09:57:52 am »
Thanks 78. Nice setup you got there. Looks good. I have some news for you all on this actually. Turns out I will be getting HID'S here eventually. Due to some unfortunate circumstances, (my buddy's truck got T-boned, 79 GMC K20), he's going to be removing the headlights and going with LED'S when the front end is rebuilt. Both head lights are in proper working order. They are Morimoto Sealed 7's, 7 inch round, HID head lights with ballasts, wiring harnesses, mounting brackets and all needed to install them on my truck. He's going to be selling them to me for a reduced price. Here's the best pic I have at the moment.
LTZ Cheyenne C20
Offline Kren420
  • 1986 C10 Silverado
« Reply #28 on: July 15, 2015, 01:30:29 pm »
Well good things can happen from bad circumstances. Look like a sweet set of headlights.  Hope your buddy is ok!
Offline enaberif
« Reply #29 on: July 15, 2015, 01:40:05 pm »
eww those are fugly. Looks like your truck is some weird alien contraption.
