Author Topic: Front clip conversion problem  (Read 8664 times)
Offline 5l1p5tr3am
« on: June 12, 2015, 12:57:49 am »
Hi all!  I'm in the middle of converting my 73-80 front clip to an 81-87 style. I've been using Monzter's instructions (http://forum.73-87chevytrucks.com/smforum/index.php?topic=9070.0) as a guide and it's been super helpful. However, I've come to the part where I need to move the body mounts back the way he did and I've run into a roadblock because on my truck the body mount and the leaf spring mount are one piece - not two separate pieces like on his. Does anyone know what kind of trouble I'd have getting the leaf spring back on if I move the mount back about an inch?
Big thanks in advance for any input.
1979 Chevy Frankenstein
C10 diesel converted to 4x4 with 307/350/203
Re: Front clip conversion problem
« Reply #1 on: July 15, 2015, 05:03:31 am »
I have done this conversion half a dozen plus times. I have never had to move the mount.
Offline 5l1p5tr3am
« Reply #2 on: August 09, 2015, 03:05:59 pm »
Thanks for the response, blazin.  So your panels always lined up with the existing body mounts or did you find a way to work around the misalignment?  Because with the new front clip on, the header panel is about 1" to 1.5" rearward of the body mounts.
Again, I really appreciate the help. I'm at a dead stop on my project right now :-(
« Reply #3 on: August 13, 2015, 12:24:23 am »
I left that portion in there but I thought I put a disclaimer on it.  I have NEVER moved the mounts on any of these.
Offline 5l1p5tr3am
« Reply #4 on: August 13, 2015, 01:17:15 pm »
I appreciate the info man, big time. After enlarging the holes in the fenders and sliding them forward as much as possible, im still about 3/4" off but at least im getting closer. So strange that they're not lining up like pretty much everyone else's but oh well. Again, thanks for your insight.
« Reply #5 on: August 13, 2015, 11:09:24 pm »
You are using the correct frame specific bushings with the clip right?  Did you start with everything loose?
This is a buddy of mines that I helped convert.  Nothing moved...  http://forum.73-87chevytrucks.com/smforum/index.php?topic=9396
Offline 5l1p5tr3am
« Reply #6 on: January 27, 2016, 03:56:58 pm »
Ended up finally finishing this front clip conversion. Came out sweet! Thanks for all your assistance and the topic in the tech section, Chris.
« Reply #7 on: January 27, 2016, 07:13:14 pm »
So what was your issue? Did you have to move the mounts?
Offline 5l1p5tr3am
« Reply #8 on: January 28, 2016, 10:59:51 am »
Thanks for reminding me, I meant to follow up on that. I didn't have to move the mounts. I used the bushing kit from an 81-87, enlarged the bolt holes on the fenders/core support a little more and massaged gaps.
Oh, I also didn't have to cut the frame horns for the bumper to mount on either. I found a post on another board that showed a way to easily modify the brackets instead. Worked great and didn't have to cut the frame!!! I'll dig up that post and make a link to it... could come in handy for others in the future.
I couldn't have done any of it without the help of the great guys on this forum tho, so thank you all again.
« Reply #9 on: January 30, 2016, 08:45:25 pm »
Glad it worked out for you. Got any pics of the swap, & truck?
