Author Topic: whats the diff  (Read 10500 times)
Offline gmc85
whats the diff
« on: September 19, 2003, 11:50:00 pm »
i was wondering what the diference was between a 73 door and an 85 because i need a door for my 85 and have a 73 door but not sure if it would line up right.
Offline gmc85
k
« Reply #1 on: September 24, 2003, 08:36:00 pm »
does any one know if there is any cosmetic diferences
:rolleyes
Offline smokin77
Re: k
« Reply #2 on: September 24, 2003, 10:22:00 pm »
As far as I know.......The outside is the same, on the inside 73-76 door shells have a smaller plastic panel than 77-87 doors. So on the inside the door shell is different.
Offline gmc85
k
« Reply #3 on: September 25, 2003, 08:10:00 pm »
ok thanks thats all i really needed to know
Offline 73K20
73 doors on an 85
« Reply #4 on: September 26, 2003, 08:44:00 am »
As mentioned they are different on the inside and use different door panels.  The exterior has the same body lines so it will match up.  The 73 door has a different window and crank mechanism than the newer 85 door.  These are not interchangeable.  You will have to use the window that came in the 73.
1973 K20 - 350/350/205
Offline gmc85
o
« Reply #5 on: September 27, 2003, 11:03:00 am »
so i cant just use my windows or there cranks or any other of the inards?
Offline smokin77
Re:difference
« Reply #6 on: September 28, 2003, 10:12:00 pm »
Pretty much!
Offline gmc85
k
« Reply #7 on: September 29, 2003, 09:27:00 pm »
well that sucks>:
Offline ITC
Re: k
« Reply #8 on: September 30, 2003, 04:57:00 am »
Yeah the regs are different... Perhaps you could drill a few holes to get the older door to work??
Offline blazer1961
Re: k
« Reply #9 on: January 23, 2004, 10:41:00 pm »
  lists the door panels as 73-76....77-87 don't know what the diff is but hope this helps.....................bob
