Author Topic: HORN REPAIR KIT  (Read 13786 times)
Offline gregmc30
HORN REPAIR KIT
« on: June 30, 2015, 11:22:30 pm »
Does anyone know where I could find a horn repair kit for my 1984 K20? I'm finding them for other vehicles but not the 73-87 chevy trucks. I'm looking for all of the parts under the horn cap. The big spring, etc.
Thanks
« Last Edit: July 01, 2015, 11:17:52 am by gregmc30 »
1984 SILVERADO K20 4X4
Re: HORN REPAIR KIT
« Reply #1 on: July 01, 2015, 08:49:29 am »
theres not really a spring for the horn, you have one for the locking plate under the steering wheel. take a picture
Offline gregmc30
Re: HORN REPAIR KIT
« Reply #2 on: July 01, 2015, 08:34:08 pm »
Here are two pics. I hope someone can tell me what I need. I'm lost.
Thanks!
« Last Edit: July 01, 2015, 08:51:54 pm by gregmc30 »
Offline Chuck Step-a-side
Re: HORN REPAIR KIT
« Reply #3 on: July 01, 2015, 08:38:53 pm »
If you have an after-market steering wheel's horn assembly like Grant, then go to the website for the spring or horn assembly. Otherwise, the factory steering wheel doesn't have a spring and would better off buying a used steering assembly or after-market steering wheel.
Your pictures are not showing. Good luck.
Offline bd
Re: HORN REPAIR KIT
« Reply #4 on: July 01, 2015, 09:58:56 pm »
Thanks
Looking at the image you posted, all of the parts appear to be there.  Why don't you tell us what you are trying to accomplish.  Is it that the horn doesn't sound?
Offline gregmc30
Re: HORN REPAIR KIT
« Reply #5 on: July 01, 2015, 10:40:16 pm »
Hmmmm...if all of the correct parts are there, now I'm thinking it may have been assembled wrong. I just purchased this truck. The problem I have is the horn cap does not push in and the horn does not sound. The horn cap is "bottomed out" and stays in the pushed in position. Does anyone know where there may be a diagram or picture showing how all of these parts should be assembled?
Thanks!
Offline bd
Re: HORN REPAIR KIT
« Reply #6 on: July 02, 2015, 01:23:24 am »
Are you missing the horn contact spring plate (imaged below) between the steering wheel and the horn button cup?  The plate is an obsolete part and may need to be procured from a salvage yard.  Occasionally the spring plate can located new at an exorbitant price.  Virtually all Saginaw steering columns use the same spring plate, so don't restrict yourself to just Chevy and GMC.
The spring plate serves as the electrical contact between the horn relay circuit and steering shaft (ground).  It also holds the horn button in the "up" position.  I suspect that someone also removed the 3-prong horn relay and/or the horns.
Offline gregmc30
Re: HORN REPAIR KIT
« Reply #7 on: July 02, 2015, 08:27:47 am »
bd   You are correct. That is the part I'm missing. Everything else is there including the relay. I'll be hitting the salvage yards. Thanks!
Offline bd
Re: HORN REPAIR KIT
« Reply #8 on: July 02, 2015, 10:56:27 am »
Found a new one for a sane price at Napa (P/N: NOE 7352951).  Of course, you'll need to verify the fit in your column.
Offline gregmc30
Re: HORN REPAIR KIT
« Reply #9 on: July 02, 2015, 12:24:51 pm »
Got the part ordered. I'm not out much if it doesn't fit. Will you look at the pin below and see if it is installed correctly?
Thanks
Offline bd
Re: HORN REPAIR KIT
« Reply #10 on: July 02, 2015, 12:58:42 pm »
Looks right.  If you ground that spring-loaded pin with a screwdriver, the horn relay should click and the horn should sound.  If it doesn't, you need to break out your test light and start checking.
Clean up that narrow mantle just below the steering shaft nut, so that it's nice and shiny - it is the ground contact for the spring plate.
