Author Topic: Wiring for 400 Transmission Kickdown  (Read 4391 times)
Offline harcorshe
« on: July 26, 2015, 05:33:42 pm »
'78 K20 454/400
The molded plug for my kickdown switch is gone.
There is a frayed single orange wire through the firewall that should go a single terminal on the transmission housing.
The switch appears to be activated by a two-wire trigger on the accelerator pedal: orange off through the firewall, and brown/white to pick up power at the fuse box. This is confirmed by the Wiring Diagram.
I ordered a replacement and the molded plug has two receptacles and two wires, an orange and a black.
What to do with the black? Ground on the chassis? Cut it off? Where was the original circuit grounded?
Thanks for your help!
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Re: Wiring for 400 Transmission Kickdown
« Reply #1 on: July 26, 2015, 06:38:39 pm »
The detent solenoid is case grounded. Are you saying the pigtail has an extra terminal? If so just leave it, It can be used for future
Offline harcorshe
« Reply #2 on: July 26, 2015, 08:49:56 pm »
Thank you sir.
'78 K20
454
TH400
14 Bolt
205 Transfer Case
