Author Topic: Bedliner as undercoating  (Read 4378 times)
Offline stretch86
« on: August 04, 2015, 09:44:23 pm »
K have a 86 c10 suburban and the frame and floors are in real good shape. Im thinking about getting a wire brush to scrap frame with to remove any flaking paint/rust, then using gray rustoleum primer that ill brush on and using the rustoleum bed liner that ill brush/roll on frame and underside of floors. Ill also give it a good washing before painting but id like to know if this would be a good way of preserving it also i live in the rust belt if it helps but truck will be parked during winter.
Offline stretch86
Re: Bedliner as undercoating
« Reply #1 on: August 05, 2015, 10:33:29 am »
Also thought about using the rustoleum professional gloss black enamel thats oil based has anyone tried either of these as an undercoating the enamel is 20 bucks cheaper per gallon as well
Offline philo_beddoe
  • 77 C-10
« Reply #2 on: August 05, 2015, 04:02:05 pm »
i used the oil base professional on another truck.  but i just coated my 77 c-10 with the rustoleum truck bed coating, which worked much much better.  it dries very hard and is textured, best of all you can get it in a spray can to use for touch up work. great price too.  1/2 gal coated my 8 ft bed heavy twice.
Offline stretch86
« Reply #3 on: August 05, 2015, 05:24:09 pm »
My local walmart has the bedliner in a gallon for 43 and the enamel for 23. e used the bedliner before but was wondering how itd do as an undercoating
  • 77 C-10
« Reply #4 on: August 24, 2015, 11:26:10 am »
I use the spray as a little touch up under coating. It actually works well, very tough, better than the rubberized and wont wear off easy from harsh salty winters.
