Author Topic: suggest me a cam  (Read 10658 times)
Offline padlock1978
suggest me a cam
« on: August 14, 2015, 08:27:20 pm »
I wanna go with a smaller cam
Motor is a 355
6" rod
Forged crank and rods,
Wiseco flat top Pistons,
arp bolts
540 lift hydraulic cam  (Too big)
PRW 350 3/8 1.6l roller rockers
Weiand intake
Edelbrock 750
Headman long tube headers
What would you all suggest?
I'm going to be using the truck for trips to the store for beer and smokes. Getting items from Menards from time to time.  Trips to the sand dues and some mud bogging.
Re: suggest me a cam
« Reply #1 on: August 15, 2015, 03:04:56 am »
What's the existing camshaft duration at 0.050" and engine compression ratio?  How about transmission, drive gear & tire diameter?  Have the heads been reworked?
Offline padlock1978
« Reply #2 on: August 15, 2015, 08:51:20 am »
Trans is a 700R4 for right now. 3:73 gears will be going 4:11 tires are 35's As for the other questions I have no clue
Offline bukweet
« Reply #3 on: August 16, 2015, 11:39:01 am »
Call a few cam manufacturer's tech lines.
Have all the above mentioned info plus vehicle/weight. Let them tell you what is best for your combo/purpose.
Check with more than one.
They want you to be happy with their product.
Livin' for Him because He died for me.
Offline 87max
« Reply #4 on: August 16, 2015, 06:13:51 pm »
completion cams xtreme energy, by far my favorite. I had run a 268 & 280 high energy comps & this cam blew them away, I would probably go down in carb size also. My motor was virtually identical to what yours is.
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
Offline padlock1978
« Reply #5 on: August 16, 2015, 08:32:49 pm »
I agree on the carb size. I plan in trying to trade the 750 for a 600-650
Offline padlock1978
« Reply #6 on: August 16, 2015, 08:37:45 pm »
http://www.summitracing.com/parts/cca-12-239-3/overview/
I have been looking at this one?
Brand:COMP Cams
Manufacturer's Part Number: 12-239-3
Part Type:Camshafts
Product Line:COMP Cams Xtreme 4x4 Camshafts
Summit Racing Part Number:CCA-12-239-3
UPC: 036584038207
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,300-5,600
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 226
Duration at 050 inch Lift: 218 int./226 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.462 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.462 int./0.480 exh.
Lobe Separation (degrees): 111
Computer-Controlled Compatible: No
Grind Number: CS X4 262H-11
Valve Springs Required: Yes
Offline rich weyand
« Reply #7 on: August 16, 2015, 10:08:29 pm »
Brand:COMP Cams
That should work.  Make sure you change the lifters, required for any cam change, and make sure you change the valve springs, required for that amount of lift.  Use the COMP recommended lifters and springs.  Run it in as per instructions, and use ZDDP in your oil, even after break-in.
As you suspect, the carb is too big.  A normally aspirated 350 cannot pump more than 500 cfm.  You will get better response and mileage from the proper carb.
Once you are set up, you should be looking at 300+ hp at 4500 and 400+ lbft at 2500, which are nice numbers.  Go much over that and you will need to redesign the whole drivetrain to keep from dumping parts on the street.
Offline 87max
« Reply #8 on: August 17, 2015, 06:03:55 pm »
I ran vac secondary & double pumpers but by far the best was a built qjet by a very good builder. Best part was the carb was an even trade for the two holleys as the guy I traded couldn't leave well enough alone & wanted a holley. Another nice pick me up was  lighter springs in the HEI.
98 Taurus beater
Offline padlock1978
« Reply #9 on: August 22, 2015, 09:35:55 pm »
Thank you for the input. I plan on going a monster trans and planning on going over to a 205 TC and I ahve 3/4 ton axles that I need to rebuild and put in.
Offline 87max
« Reply #10 on: August 23, 2015, 07:21:12 pm »
I splattered a few trannies over the years. Best one that lasted me the longest was a T400 with A1 22% cut planetaries. I ran 2 sets of TCI 11% but they were just modified 700r sets. I sheared both in half. TCI was good & gave full refund but it was total teardown of the tranny each time. 205 was also best case I ran never had a single issue with either of the two I used. Biggest lesson learned was not to use a stall converter, I broke three new dacco brand of various stalls. Only one that lasted me was a stock one from a school bus. That was an expensive two summers.
98 Taurus beater
