Author Topic: 6.0 turbo blowthrough build  (Read 34479 times)
Offline Flyinhillbilly
Re: 6.0 turbo blowthrough build
« Reply #15 on: March 06, 2016, 09:22:22 pm »
Idle video. Turbo seems like it's going to spool in a hurry.
http://youtu.be/yf7puM-kW1s
I was born on a mountian, raised in a cave,
Overpowered cars is all I crave.
« Reply #16 on: March 08, 2016, 11:18:26 pm »
Got the exhaust built, I'll take it to the muffle shop in the morning and have him put a couple of hangers on it for me. Just a few more things to do and it's time for positive intake manifold pressure.
http://youtu.be/2CaxP5wSUwg
Offline SomeTexan
  • No such thing as too much hp
« Reply #17 on: March 08, 2016, 11:25:09 pm »
Looking good. I would have kept the 6.0 and efi, but either way it's a cool build.
86 swb c10, LQ4/glide with 80mm turbo
« Reply #18 on: March 18, 2016, 02:46:15 pm »
Thanks. I really wanted to do the 6.0, but I had to get in a hurry as the engine that was in the truck was about to the end of it's service life and it seemed more practical to just do a 23degree engine since everything would fit and I could get it done in a hurry. This is my daily driver, so it couldn't take on "project " status.
Offline SomeTexan
« Reply #19 on: March 18, 2016, 05:07:20 pm »
I understand that. It always sucks when you start a build and the old engine starts letting go before you are ready.
« Reply #20 on: March 21, 2016, 09:13:51 pm »
Boosted the truck for the first time tonight. I have the secondaries unhooked at the moment because I like to tune out my primaries and power valve channel restrictors first and then jet the secondaries, but even on the tiny primaries, this thing rips. Video as soon as I can find someone with the nerve to ride in it with me under boost.
Offline FlatBlack77
« Reply #21 on: March 21, 2016, 10:33:56 pm »
cant wait!
« Reply #22 on: March 22, 2016, 12:18:19 pm »
Offline FlatBlack77
« Reply #23 on: March 22, 2016, 10:27:21 pm »
MOAR
« Reply #24 on: March 24, 2016, 09:26:14 am »
Going to try and get the secondaries hooked up and tuned out this weekend. That video was on the primaries only and 3 big boost leaks to help keep it at a reasonable level during the first tuning steps. I think it's going to be pretty fast for an old truck.
Offline frotosride
    • WFO CONCEPTS
« Reply #25 on: March 24, 2016, 09:07:10 pm »
Can't wait to see this!  It makes me wanna order TT'S for the 6.0l tonight!
Offline SomeTexan
« Reply #26 on: March 24, 2016, 09:46:31 pm »
You will like a single 76-88mm more. I've done both and would only go with twins if I can't fit a big single.
« Reply #27 on: March 27, 2016, 12:57:06 pm »
I concur. The only real reason to do twins IMO is if you can't get the big single down pipe out of the engine compartment, well, that or if you just find a smokin deal on a set of twins or just like the look.
« Reply #28 on: March 29, 2016, 11:46:17 am »
I've always wondered about why people do twins. On my Cummins I have the hx35 she spools up quick and I'm running 40 lbs. I mean what else could a twin do that this hx can't?
Offline SomeTexan
« Reply #29 on: March 29, 2016, 12:09:23 pm »
Well, nobody actually runs twin turbos on a Cummins. They run compound turbos. The small turbo spools quickly and gets you boosted and going fast, but then the big turbo takes off and gives you more boost at a lower temp than the smaller turbo would. They are a waste of time and money if you are not far from stock, but if you have a lot of mods it is a huge drivability improvement over a big single. Going to twins made my old pull truck go from something I towed to the track and that's it, to a truck that I actually wanted to drive daily.
There is a company that makes a supercharger over a big turbo, compound set up that is pretty impressive. It idles at about 10lbs will light a big turbo almost instantly. I was very impressed with the one I drove.
