Author Topic: Mystery problem  (Read 3425 times)
Offline 1987GMCSierra
Mystery problem
« on: August 21, 2015, 10:47:17 am »
I had been dealing with issues on my 1987 GMC for awhile, and gave in and dropped a new Jasper 305 in. After installing the new engine, I have been experiencing a new issue where the truck will die after I turn the ignition over. It only seems to happen when it's hot out (which is 24/7 - I live in SC) or when its been driven a lot that day. As soon as I turn it over it will die unless I give it a little gas. When I throw it in neutral, reverse or drive it will die as well - until I get going. I have taken to multiple repair shops and they're all stumped. Here's a list of what has been recently replaced/checked.
-New Jasper 305 Engine
-New EGR Valve
-New MAP Sensor
-New engine coolant sensor
-New Fuel Pump, fuel lines
-No codes being produced
-Fuel injection running clean
I have a bottle of your favorite liquor if you could help me solve this issue. I'm at my wits end!
Re: Mystery problem
« Reply #1 on: August 21, 2015, 04:46:55 pm »
  • Have you verified base ignition timing with the brown/black ESC bypass wire disconnected?  What is it?
  • Have you measured the fuel pressure?  What is it?
  • Remove and plug the vacuum hose connected to the EGR valve.  Is there any improvement?
  • When started cold, does it initially throttle up on its own?
  • Do you have a test light?
« Last Edit: August 21, 2015, 04:52:44 pm by bd »
Re: Mystery problem
« Reply #2 on: August 21, 2015, 05:16:12 pm »
does it just die or does it misfire/run like crap then die
