Author Topic: Reverse clunk noise??  (Read 6015 times)
Offline Kimper
  • NP203
« on: August 31, 2015, 12:58:00 pm »
I have a 76 Chevy k10 with a th350, np203 and 12 bolt rear end. I brought to a shop to get the rear end looked at because with the rear wheels off the ground and the tranny in neural I couldn't move the rear tires forward. It would also clunk when put in reverse so I thought the backlash was out. Well the spider gears were messed up along with the ring and pinion so I had the whole thing rebuilt. The truck seemed fine when I got it back and everything was great but I am now getting the clunking when I put it in reverse. If I shift it slow it is usually fine but if I shift it like a normal person puts a truck in reverse it clunks. I have read about the slip joints needing grease but I am not sure if this would cause it or not. Any info would be greatly appreciated..
You shut your mouth when you're talking to me!!!
Offline enaberif
Re: Reverse clunk noise??
« Reply #1 on: August 31, 2015, 01:02:33 pm »
ujoints in driveshaft
Offline ehjorten
« Reply #2 on: August 31, 2015, 01:43:25 pm »
NP203 is a Chain-drive transfer case.  The chain does not have any provisions for a tensioner.  The chain has stretched and it is providing the slop!  If everything is good with your rear differential and propshaft u-joints are good, then it is simply this chain slop.  It won't hurt anything.  My '77 has had this clunk for more than a decade with no issues.
-Erik-
Offline Kimper
  • NP203
« Reply #3 on: August 31, 2015, 05:11:12 pm »
Thanks for the tips, I am going to Crawl under it this week and have my wife HOLD THE BRAKES and put it in reverse and look and listen for if its a U joint, rear end, or transfer case
Offline enaberif
« Reply #4 on: August 31, 2015, 05:44:51 pm »
no no no bad bad. just grab the shafts and move them around. they should be tight with minimal movement.
Offline Kimper
  • NP203
« Reply #5 on: August 31, 2015, 08:44:50 pm »
Well I have grabbed them and they seem tight but the guy who do my rear end said one of the u joints were in backwards and he couldn't get to the zerk fitting to greese it if that matters??
« Reply #6 on: September 04, 2015, 04:04:53 pm »
Doesn't matter just means  you can service it.
« Reply #7 on: September 04, 2015, 07:37:11 pm »
transmission mount can cause a clunk if its bad
