Author Topic: Side exit exhaust. Anyone have this?  (Read 20007 times)
Offline jarhead79
« on: September 11, 2015, 12:00:23 pm »
I'm need to cut off the rear half of my exhaust because it's rusted and full off holes, I can pick the rust off in chunks and it leaves a hole so it's time to upgrade a little. Anyone have pics of their side exit exhaust setups?!
« Last Edit: September 11, 2015, 12:37:54 pm by jarhead79 »
Offline Bishop1989
Re: Side exit exhaust. Anyone have this?
« Reply #1 on: September 14, 2015, 06:43:44 pm »
I took these tips off and I'll have new ones on it this weekend.
1986 K10 Silverado 5.0L
Offline FlatBlack77
« Reply #2 on: September 14, 2015, 07:12:46 pm »
here is mine. 2 1/2 inch pipes.
i used a 90 degree elbow to point out the side and i used a bolt hole in the spring hangers to mount the exhaust hangers.
the other side clears the fuel tank no problem
« Last Edit: September 14, 2015, 07:15:58 pm by FlatBlack77 »
« Reply #3 on: September 16, 2015, 03:29:09 pm »
wish i had a good cell phone back when i had my 86 on the road. had my exhaust 45 before the rear tires and had 6" tips on it. this was behind headers with glass packs. she was loud
Offline Scowling
« Reply #4 on: October 27, 2015, 12:58:23 pm »
I know this topic is old. But instead of starting a new thread I thought I'd add on to this. What would you guys recommend for space clearance between fuel tank and exhaust tip?
I have a '86 c3500 cab and chassis. my exhaust is all rotted out too and I'm wanting to either do dual side exhaust or 45 dump in front of the rear axle. Just don't want to run the exhaust too close to the dual fuel tanks
« Reply #5 on: October 27, 2015, 01:04:39 pm »
On my 86 I ran my tips probably about a inch under the tanks. Now these were 5 or 6" tips
« Reply #6 on: October 27, 2015, 01:32:07 pm »
Mine have about 3/4" of clearance here:
Offline Scowling
« Reply #7 on: October 27, 2015, 04:55:55 pm »
Thanks for the info guys. I didn't want to do something stupid and end up flying down the highway in a ball of flames
Offline warwagon85
« Reply #8 on: January 11, 2016, 11:16:26 pm »
Here the set up I've always had.  Once with converters.  I just had the exhaust redone minus converters.
Offline cubicdollars
« Reply #9 on: September 13, 2016, 07:40:02 am »
I dumped mine right below the step on my stepside, it's loud as heck but awesome!!
