Author Topic: Check this out!  (Read 5372 times)
Offline Kallaorf
Check this out!
« on: September 29, 2004, 01:29:00 am »
I have an 86 c-10 pickup...the parallel run between the bottom of the rear window and the front of the bed rail is off, as much as 3/4 inch on the passenger to the driver side. Ive seen other C-10's like this and was wondering if there is a fix for it. My body lines on the side are dead on, and I had the frame checked for straightness before bagging it.
Thanks in advance.....Bro
Edited by: Kallaorf at: 9/29/04 12:29 am
Offline bigblock73
  • Yeller
Re: Check this out!
« Reply #1 on: September 29, 2004, 12:05:00 pm »
Are your cab mount bushings shot or on backwards (if they are new)?  How about the cab mounts themsleves?
Did you have your V8 today?  :D
...Jeff
'73 swb 2wd
'77 Blazer 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline Kallaorf
Re: Check this out!
« Reply #2 on: September 29, 2004, 03:00:00 pm »
They are stock, and last time I looked they were kinda shot lookin but even. I'll have to check them front ones out. But they most likely need to be replaced by now.
Thanks...Bro
Edited by: Kallaorf at: 9/29/04 2:00 pm
