Author Topic: '75 K10 Removing NP205  (Read 6688 times)
Offline BBM3
« on: September 23, 2015, 05:31:08 pm »
Is there a preferred method?
1) Remove the NP205 along with the SM465 transmission adapter.
2) Leave the adapter attached to the SM465.
Thanks,
-BB
Offline fitz
Re: '75 K10 Removing NP205
« Reply #1 on: September 24, 2015, 08:48:00 am »
Any chance of using a lift?
« Reply #2 on: September 24, 2015, 09:02:36 am »
well the adapter is the only thing holding the trans in place so if you remove that the trans will fall. i would op for leaving the adapter on the trans so it makes the 205 a little lighter. dont be under it or near it when you pull it out and you have to slide it out before it will come down
Offline BBM3
« Reply #3 on: September 24, 2015, 12:42:14 pm »
Yes, the tuck is on my 4 post lift.
That makes sense. I'll be removing the transmission after the T case.
I'll leave the adapter attached to the trans.
Thanks for the replays!
Offline BBM3
« Reply #4 on: September 26, 2015, 03:11:13 pm »
I want to follow up in case anyone in the future has the same question.
My Answer to My Question...
Remove the NP205 along with the SM465 transmission adapter!
I was able to get the T-Case out without removing the trans mount / adapter and forward crossmember but it was a pain.
Some of the fasteners were nearly impossible to access and remove.
Before I reinstall I'll support the transmission, remove the crossmember, mount the adapter to the T-Case, and rent a transmission jack for the transfer case.
« Last Edit: September 26, 2015, 04:53:18 pm by BBM3 »
