Author Topic: Stalling issue in 350 tbi  (Read 5016 times)
Offline Jakethesnake73
« on: September 26, 2015, 07:29:21 pm »
I madr a trip up i70 earlier this year and at my exit had a stalling issue that was just like vapor locking. The longer i waited to start the longer i could drive. Most of my driving is just around town. Today i drove about 9 miles and stalled in the turn lane right before where i was going thank fully. Cranked for a while and finally started just to stall again while waiting for traffic so i could turn.
Im thinking its
Fuel pump, kinked line somewhere, or the fuel filter. Thoughts?
Re: Stalling issue in 350 tbi
« Reply #1 on: September 26, 2015, 10:53:14 pm »
well i hope this helps you out
http://forum.73-87chevytrucks.com/smforum/index.php?topic=29996.0
02 sensor and tps can cause stalling.
any check engine light?
i would also check for spark and do you hear the fuel pump prim and run?
Online bd
« Reply #2 on: September 26, 2015, 11:06:10 pm »
Remove the fuel tank cap and test drive the truck.  If the symptoms persist try replacing the fuel filter.  If they still persist, check the fuel pressure.
« Reply #3 on: September 27, 2015, 07:30:33 pm »
i can hear the fuel pump prime when i turn the key on. I have never been able to hear it while driving. My o2 sensors would bring a check engine light every once in a while and it read code 44 i think. It was for lean oxygen. I havent had the check engine light turn on since i cut the cats off. Just driving around town i have the issue now. Its a lot like vapor locking. I know that i have a slightly kinked line at the gas tank. Today it started as stalling at lights and now i cant get anywhere without stopping for a while.
Offline jaredts
« Reply #4 on: September 27, 2015, 09:14:28 pm »
Follow BD's advice.  Or you could jump right to the fuel pressure check and eliminate several things at once.
« Reply #5 on: September 28, 2015, 01:30:27 am »
pulled the cap today and continued to stall. I will try a new filter andcheck the pressure when i get a chance
« Reply #6 on: September 30, 2015, 11:36:24 am »
I put my cats back on and it seems to work now
