Author Topic: bad vibration  (Read 387991 times)
Re: bad vibration
« Reply #465 on: August 30, 2026, 07:06:02 pm »
It's not the torque converter. Pull the plugs, check the cap and rotor.
Offline philo_beddoe
  • 77 C-10
Re: bad vibration
« Reply #466 on: August 30, 2026, 08:54:04 pm »
Ok, will do!
  • 77 C-10
Re: bad vibration
« Reply #467 on: August 31, 2026, 04:07:06 pm »
Are these bad? Clean, replace??
Sent from my SM-S942U1 using Tapatalk
Re: bad vibration
« Reply #468 on: August 31, 2026, 05:19:29 pm »
Time for a tune up  8)
  • 77 C-10
Re: bad vibration
« Reply #469 on: August 31, 2026, 05:48:21 pm »
I did the plugs a month ago, R45TS. Should I add in new wires, I have cap and rotor in my cart right now.
…still have same wires you put on.
Re: bad vibration
« Reply #470 on: September 02, 2026, 05:06:31 pm »
Did it start running rough after you did the plugs?
  • 77 C-10
Re: bad vibration
« Reply #471 on: September 02, 2026, 08:05:29 pm »
No, it was smooth. I just got a new dist. cap, rotor and plug wires. I’ll check and make sure each plug is sparking.
  • 77 C-10
bad vibration
« Reply #472 on: September 03, 2026, 06:29:24 pm »
No change at all, new dist cap, rotor and plug wires. The only thing I saw back there not connected was this. What is it and where does it go? Connection for optional tachometer?
« Last Edit: September 03, 2026, 10:05:56 pm by philo_beddoe »
Re: bad vibration
« Reply #473 on: September 04, 2026, 02:58:29 pm »
Pull your plugs, check the gaps, make sure none of them are cracked. That is oil pressure sending unit or switch. Do you have gauges or lights?
  • 77 C-10
Re: bad vibration
« Reply #474 on: September 05, 2026, 06:26:14 pm »
Solved!!
It was those tiny primary idle tubes. I removed both idle mixture screws and shoved the thin red hose up there deep and blasted with my firearm bore cleaner and then carb cleaner, repeat, rinse, repeat. Waited 10 minutes then blasted the compressed air up there, fuel and cleaner blew right up and out the top. Put the screws back in and backed them out accordingly. Fired right up and was as smooth as ever.
Oh, I have all dash lights, and oil pressure gauge is reading fine, so where (physically) does that thing connect on to??
Thanks!
