Engine/Drivetrain
bad vibration
32
Topic: bad vibration (Read 387990 times)
philo_beddoe
77 C-10
bad vibration
October 17, 2015, 10:15:27 pm »
Surprised i couldent find some old posts on this. 2wd c10, starting to notice a pulsating vibration at about 45-50 mph. Feel it right through the seats, not the steering column. Most likely u joints?? How do you check or test them?
Last Edit: January 09, 2016, 02:56:41 pm by Irish_Alley
Behold, the day of the LORD cometh, and thy spoil shall be divided in the midst of thee. Zechariah 14:1
85ckaz
Re: Pulsating vibration at 50
October 18, 2015, 01:57:52 pm »
I replaced the transmission mount in my K20 to eliminate the same issue. To check U joints just push on the drive shaft and you should have no movement. I would also check the pinion gear bearings/ rear diff yoke for movement. They should be tight. If there is slop in anything it needs to be repaired/ replaced.
philo_beddoe
77 C-10
October 19, 2015, 08:06:55 am »
I'm on it! Thanks!
philo_beddoe
77 C-10
October 20, 2015, 07:32:44 am »
New tires and factory rims, but i'll check the weights anyway. It is not "shuddering" like a bad unbalanced wheel, more of a steady vibrate, hardly pulsating i guess, seems to smooth out near 60 mph. I tried to move driveshaft, tight as a drum.
philo_beddoe
77 C-10
October 20, 2015, 07:37:16 am »
....oh and yes, one piece shaft, as far as being a new problem.,, we'll im just now noticing. I guess i'll let it go for now. My mechanic is a chevy guy, (i only use him when a garage is needed), im getting new exh manifolds put on soon, i'll have him take a look.
philo_beddoe
77 C-10
October 22, 2015, 10:15:28 pm »
Not sure what you mean "out of phase"
philo_beddoe
77 C-10
October 27, 2015, 05:26:14 pm »
That makes good sense., but i have a one piece shaft.
philo_beddoe
77 C-10
October 27, 2015, 05:29:21 pm »
....or does it matter in terms of speaking out of phase?
philo_beddoe
77 C-10
October 28, 2015, 09:50:29 am »
I will take a look. It seem to let up when i let off the gas. Does this make sense?
October 28, 2015, 10:41:51 am »
Yes. I know with my crew cab I had a vibration. I replaced the carrier bearing and my shaft was out of phase fixed both them and the vibration under throttle went away.
philo_beddoe
77 C-10
October 28, 2015, 08:39:12 pm »
Carrier bearing? Ok, where is it and what does it look like? I have not delved into that area too much.
October 28, 2015, 09:02:15 pm »
The carrier bearing will be in the driveshaft.
philo_beddoe
77 C-10
Reply #12 on:
October 28, 2015, 09:30:08 pm »
Ok, will have a look, thanks.
Reply #13 on:
October 28, 2015, 09:36:07 pm »
Carrier bearing won't be found on your truck. Only 2+ piece drive shafts. It keeps the driveshaft in line. There's a physical limit to how long/thick a driveshaft can be. So they have to split it up in a couple different sections. Fist section will have the driveshaft bolted to the transmission or transfer case. Then a few feet down the carrier bearing attaches to the frame to keep it in line then you have male splines on the end of the first shaft and a female slip yoke drive shaft that will bolt to the rear
philo_beddoe
77 C-10
Reply #14 on:
October 28, 2015, 09:52:02 pm »
Ok, appreciate the feedback. Maybe it's the flux capacitor...lol. I will get under there and check correct phase first, check ujoints again, etc.
32
Engine/Drivetrain
bad vibration
