Author Topic: One wire alternator  (Read 3665 times)
Offline RebelSon
One wire alternator
« on: October 18, 2015, 08:14:26 am »
I have a 84 C10 that i'm wanting to convert to a one wire alternator. How do I go about it? And will my stock volt gauge still work? Detail would be much appreciated. Thanks
Re: One wire alternator
« Reply #1 on: October 18, 2015, 04:58:33 pm »
i took my alt to a shop where he made it one wire and made it excite at a few hundred rpms. he plugged the hole for the connection so it only had the main power wire on it and my gauge still worked fine. think it cost $60 to make it a one wire. im not sure what he did. but im interested in finding out
Offline RebelSon
« Reply #2 on: October 18, 2015, 06:48:09 pm »
Thanks Irish for the reply back.. I should have made myself more clearer, sorry I didn't.. I have a 100 amp alt that is made for a one wire set up..  So i was needing to know how it would be wired to keep battery charged.. I finally found a video on youtube saying to run  a 10 gauge wire from the back of the alt to the positive on battery or to the positive on starter.. But it doesn't say if the factory volt gauge will still work or not
« Reply #3 on: October 18, 2015, 07:04:56 pm »
ahh yeah it should work and run the 10 ga like you saw in the video and you will be good. did you do the one wire alt yourself or someone else?
Offline RebelSon
« Reply #4 on: October 18, 2015, 07:22:44 pm »
Thanks for your help.. I bought the alt new chrome, water pump, power steering pump, AC compressor, and billet pulleys all in a kit I found on ebay
